[i.MX] 天嵌E9 的 U-BOOT 的 DCD表生成出来,u-boot 启动不了
4871|11
 楼主| sulinux 发表于 2014-11-3 14:24 | 显示全部楼层 |阅读模式
本人使用天嵌E9的 DEMO, 使用《I.MX6DQSDL DDR3 Script Aid V0.10》脚本生成RealView.inc,
本人的脚本配置
        Device Information
        Manufacturer:        Samsung
        Memory part number:        K4B4G1646B HCK0
        Memory type:        DDR3-1600        1600
        DRAM density (Gb)        4
        DRAM Bus Width        16
        Number of Banks        8
        Number of ROW Addresses        15
        Number of COLUMN Addresses        10
        Page Size (K)        2
        Self-Refresh Temperature (SRT)        Normal
        tRCD=tRP=CL (ns)        20.834
        tRC Min (ns)        73.866
        tRAS Min (ns)        53.032
        System Information
        i.Mx Part        i.Mx6Q        Arik
        Bus Width        64
        Density per chip select (Gb)        16
        Number of Chip Selects used        1        If only one CS is used, that must be CS0.
        Total DRAM Density (Gb)        16
        DRAM Clock Freq (MHz)        528
        DRAM Clock Cycle Time (ns)        1.894
        Address Mirror (for CS1)        Disable
        SI Configuration
        DRAM DSE Setting - DQ/DQM (ohm)        40        40ohm is used in FSL reference design.
        DRAM DSE Setting - ADDR/CMD/CTL (ohm)        40        40ohm is used in FSL reference design.
        DRAM DSE Setting - CK (ohm)        40        40ohm is used in FSL reference design.
        DRAM DSE Setting - DQS (ohm)        40        40ohm is used in FSL reference design.
        System ODT Setting (ohm)        40
生成的表转化成 u-boot 里面的格式,
dcd_hdr:          .word 0x40A802D2 /* Tag=0xD2, Len=84*8 + 4 + 4 = , Ver=0x40 */
write_dcd_cmd:    .word 0x04A402CC /* Tag=0xCC, Len=84*8 + 4 = , Param=0x04 */
//init script for i.Mx6Q DDR3        E9
// Revision History
// v01
// IOMUX
// IOMUXC_BASE_ADDR = 0x020e 0000
//DDR IO TYPE:
MXC_DCD_ITEM(1,0x020e0798 ,        0x000C0000)        // IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
MXC_DCD_ITEM(2,0x020e0758 ,        0x00000000)        // IOMUXC_SW_PAD_CTL_GRP_DDRPKE
//CLOCK:
MXC_DCD_ITEM(3,0x020e0588 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0
MXC_DCD_ITEM(4,0x020e0594 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1
//ADDRESS:
MXC_DCD_ITEM(5,0x020e056c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS
MXC_DCD_ITEM(6,0x020e0578 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS
MXC_DCD_ITEM(7,0x020e074c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_ADDDS
//Control:
MXC_DCD_ITEM(8,0x020e057c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET
MXC_DCD_ITEM(9,0x020e058c ,        0x00000000)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS
MXC_DCD_ITEM(10,0x020e059c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0
MXC_DCD_ITEM(11,0x020e05a0 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1
MXC_DCD_ITEM(12,0x020e078c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_CTLDS
//Data Strobes:
MXC_DCD_ITEM(13,0x020e0750 ,        0x00020000)        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL
MXC_DCD_ITEM(14,0x020e05a8 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0
MXC_DCD_ITEM(15,0x020e05b0 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1
MXC_DCD_ITEM(16,0x020e0524 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2
MXC_DCD_ITEM(17,0x020e051c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3
MXC_DCD_ITEM(18,0x020e0518 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS4
MXC_DCD_ITEM(19,0x020e050c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS5
MXC_DCD_ITEM(20,0x020e05b8 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS6
MXC_DCD_ITEM(21,0x020e05c0 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS7
//Data:
MXC_DCD_ITEM(22,0x020e0774 ,        0x00020000)        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE
MXC_DCD_ITEM(23,0x020e0784 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B0DS
MXC_DCD_ITEM(24,0x020e0788 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B1DS
MXC_DCD_ITEM(25,0x020e0794 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B2DS
MXC_DCD_ITEM(26,0x020e079c ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B3DS
MXC_DCD_ITEM(27,0x020e07a0 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B4DS
MXC_DCD_ITEM(28,0x020e07a4 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B5DS
MXC_DCD_ITEM(29,0x020e07a8 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B6DS
MXC_DCD_ITEM(30,0x020e0748 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_GRP_B7DS
MXC_DCD_ITEM(31,0x020e05ac ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0
MXC_DCD_ITEM(32,0x020e05b4 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1
MXC_DCD_ITEM(33,0x020e0528 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2
MXC_DCD_ITEM(34,0x020e0520 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3
MXC_DCD_ITEM(35,0x020e0514 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM4
MXC_DCD_ITEM(36,0x020e0510 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM5
MXC_DCD_ITEM(37,0x020e05bc ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM6
MXC_DCD_ITEM(38,0x020e05c4 ,        0x00000030)        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM7
// DDR Controller Registers
// Manufacturer:        Samsung
// Device Part Number:        K4B4G1646B HCK0
// Clock Freq.:         528MHz
// Density per CS in Gb:         16
// Chip Selects used:        1
// Number of Banks:        8
// Row address:            15
// Column address:         10
// Data bus width        64
// MMDC_P0_BASE_ADDR = 0x021b 0000
MXC_DCD_ITEM(39,0x021b001c ,        0x00008000) //MMDC0_MDSCR, set the Configuration request bit during MMDC set up
// Calibration setup.
MXC_DCD_ITEM(40,0x021b0800 ,        0xA1390003)        // DDR_PHY_P0_MPZQHWCTRL, enable both one-time & periodic HW ZQ calibration.
// For target board, may need to run write leveling calibration to fine tune these settings.
MXC_DCD_ITEM(41,0x021b080c  ,0x00000000)
MXC_DCD_ITEM(42,0x021b0810 ,        0x00000000)
MXC_DCD_ITEM(43,0x021b480c  ,0x00000000)
MXC_DCD_ITEM(44,0x021b4810 ,        0x00000000)
////Read DQS Gating calibration
MXC_DCD_ITEM(45,0x021b083c ,        0x00000000)        // MPDGCTRL0 PHY0
MXC_DCD_ITEM(46,0x021b0840 ,        0x00000000)        // MPDGCTRL1 PHY0
MXC_DCD_ITEM(47,0x021b483c ,        0x00000000)        // MPDGCTRL0 PHY1
MXC_DCD_ITEM(48,0x021b4840 ,        0x00000000)        // MPDGCTRL1 PHY1
//Read calibration
MXC_DCD_ITEM(49,0x021b0848 ,        0x40404040)        // MPRDDLCTL PHY0
MXC_DCD_ITEM(50,0x021b4848 ,        0x40404040)        // MPRDDLCTL PHY1
//Write calibration
MXC_DCD_ITEM(51,0x021b0850 ,        0x40404040)        // MPWRDLCTL PHY0
MXC_DCD_ITEM(52,0x021b4850 ,        0x40404040)        // MPWRDLCTL PHY1
//read data bit delay: (3 is the reccommended default value, although out of reset value is 0)
MXC_DCD_ITEM(53,0x021b081c ,        0x33333333)        // DDR_PHY_P0_MPREDQBY0DL3
MXC_DCD_ITEM(54,0x021b0820 ,        0x33333333)        // DDR_PHY_P0_MPREDQBY1DL3
MXC_DCD_ITEM(55,0x021b0824 ,        0x33333333)        // DDR_PHY_P0_MPREDQBY2DL3
MXC_DCD_ITEM(56,0x021b0828 ,        0x33333333)        // DDR_PHY_P0_MPREDQBY3DL3
MXC_DCD_ITEM(57,0x021b481c ,        0x33333333)        // DDR_PHY_P1_MPREDQBY0DL3
MXC_DCD_ITEM(58,0x021b4820 ,        0x33333333)        // DDR_PHY_P1_MPREDQBY1DL3
MXC_DCD_ITEM(59,0x021b4824 ,        0x33333333)        // DDR_PHY_P1_MPREDQBY2DL3
MXC_DCD_ITEM(60,0x021b4828 ,        0x33333333)        // DDR_PHY_P1_MPREDQBY3DL3
//For i.mx6qd parts of versions A & B (v1.0, v1.1), uncomment the following lines. For version C (v1.2), keep commented
//         0x021b08c0 ,        0x24911492        // fine tune SDCLK duty cyc to low - seen to improve measured duty cycle of i.mx6
//         0x021b48c0 ,        0x24911492
// Complete calibration by forced measurement:
MXC_DCD_ITEM(61,0x021b08b8 ,         0x00000800)        // DDR_PHY_P0_MPMUR0, frc_msr
MXC_DCD_ITEM(62,0x021b48b8 ,         0x00000800)        // DDR_PHY_P0_MPMUR0, frc_msr
// Calibration setup end
//MMDC init:
MXC_DCD_ITEM(63,0x021b0004 ,        0x00020036)        // MMDC0_MDPDC
MXC_DCD_ITEM(64,0x021b0008 ,        0x09444040)        // MMDC0_MDOTC
MXC_DCD_ITEM(65,0x021b000c ,        0x898E7958)        // MMDC0_MDCFG0
MXC_DCD_ITEM(66,0x021b0010 ,        0x48DB8F64)        // MMDC0_MDCFG1
MXC_DCD_ITEM(67,0x021b0014 ,        0x01FF00DB)        // MMDC0_MDCFG2
//MDMISC: RALAT kept to the high level of 5.
//MDMISC: consider reducing RALAT if your 528MHz board design allow that. Lower RALAT benefits:
//a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT to 3
//b. Small performence improvment
MXC_DCD_ITEM(68,0x021b0018 ,        0x00011740)        // MMDC0_MDMISC
MXC_DCD_ITEM(69,0x021b001c ,        0x00008000)        // MMDC0_MDSCR, set the Configuration request bit during MMDC set up
MXC_DCD_ITEM(70,0x021b002c ,        0x000026D2)        // MMDC0_MDRWD
MXC_DCD_ITEM(71,0x021b0030 ,        0x008E1023)        // MMDC0_MDOR
MXC_DCD_ITEM(72,0x021b0040 ,        0x00000047)        // Chan0 CS0_END
MXC_DCD_ITEM(73,0x021b0000 ,        0x841A0000)        // MMDC0_MDCTL
//Mode register writes
MXC_DCD_ITEM(74,0x021b001c ,        0x02088032)        // MMDC0_MDSCR, MR2 write, CS0
MXC_DCD_ITEM(75,0x021b001c ,        0x00008033)        // MMDC0_MDSCR, MR3 write, CS0
//MXC_DCD_ITEM(76,0x021b001c ,        0x00048031)        // MMDC0_MDSCR, MR1 write, CS0
MXC_DCD_ITEM(76,0x021b001c ,        0x00448031)        // MMDC0_MDSCR, MR1 write, CS0
MXC_DCD_ITEM(77,0x021b001c ,        0x19708030)        // MMDC0_MDSCR, MR0write, CS0
MXC_DCD_ITEM(78,0x021b001c ,        0x04008040)        // MMDC0_MDSCR, ZQ calibration command sent to device on CS0
MXC_DCD_ITEM(79,0x021b0020 ,        0x00007800)        // MMDC0_MDREF
//MXC_DCD_ITEM(80,0x021b0818 ,        0x00022227)        // DDR_PHY_P0_MPODTCTRL
//MXC_DCD_ITEM(81,0x021b4818 ,        0x00022227)        // DDR_PHY_P1_MPODTCTRL
MXC_DCD_ITEM(80,0x021b0818 ,        0x00033337)  // DDR_PHY_P0_MPODTCTRL
MXC_DCD_ITEM(81,0x021b4818 ,        0x00033337)  // DDR_PHY_P1_MPODTCTRL
MXC_DCD_ITEM(82,0x021b0004 ,        0x00025576)        // MMDC0_MDPDC now SDCTL power down enabled
MXC_DCD_ITEM(83,0x021b0404 ,        0x00011006)        // MMDC0_MAPSR ADOPT power down enabled, MMDC will enter automatically to self-refresh while the number of idle cycle reached.
MXC_DCD_ITEM(84,0x021b001c ,        0x00000000)        // MMDC0_MDSCR, clear this register (especially the configuration bit as initialization is complete)
填写到flash_header.S,但是实际运行中板并没有启动成功,也没有任何打印信息。
不知道哪一个参数设置的问题,求解
FSL_TICS_Rita 发表于 2014-11-3 16:02 | 显示全部楼层
楼主你好,请问你使用的是哪块板子?BSP版本是什么?
 楼主| sulinux 发表于 2014-11-3 16:46 | 显示全部楼层
使用的天嵌E9 开发板, 设计是参考官方的设计,BSP 版本是u-boot_1.3.4
FSL_TICS_Rita 发表于 2014-11-3 16:56 | 显示全部楼层
楼主你好,这个问题建议你先找一下天嵌的技术支持咨询一下。软件硬件都是他们自己设计的,会比较熟悉的。
评分
参与人数 1威望 +1 收起 理由
sulinux + 1 赞一个!
查看全部评分
bestray 发表于 2014-11-7 11:03 | 显示全部楼层
是不是只要使用的ddr与官方的ddr有出入都得使用《I.MX6DQSDL DDR3 Script Aid V0.10》脚本生成RealView.inc来修改flash_head.S吗?如果即使ddr规格不一样,但是默认官方设置uboot也可以启动,可不可以说明ddr设置ok呢??
 楼主| sulinux 发表于 2014-11-10 10:51 | 显示全部楼层
自己设计的和官方设计有不同的话,最好使用脚本,还需要DDR stress Tester 校准后、压力测试通过后,再去修改u-boot DCD表
FSL_TICS_Rita 发表于 2014-11-10 16:29 | 显示全部楼层
是不是只要使用的ddr与官方的ddr有出入都得使用《I.MX6DQSDL DDR3 Script Aid V0.10》脚本生成RealView.inc ...
你好,关于你以上提出的问题:
答:DDR 和官网开发板使用不一样的话,都是要重新来配置它的。否则是无法工作的。
还有你这里说是使用不同的规格DDR,使用官网默认的u-boot就能启动,不能说明DDR设置的就正确,而且DDR使用不同的话,直接使用官网的u-boot的是无法启动的。
希望以上回答能够帮助到你。
FSL_TICS_Rita 发表于 2014-11-10 16:30 | 显示全部楼层
有问题我们再沟通~~
FSL_TICS_Rita 发表于 2014-11-10 16:31 | 显示全部楼层
自己设计的和官方设计有不同的话,最好使用脚本,还需要DDR stress Tester 校准后、压力测试通过后,再去修 ...
是的,赞同。请问楼主现在u-boot可以正常启动了吗?
 楼主| sulinux 发表于 2014-11-11 11:48 | 显示全部楼层
已经可以正常启动了,但是还有疑问,详情见 https://bbs.21ic.com/forum.php?mo ... amp;fromuid=1367860
FSL_TICS_Rita 发表于 2014-11-11 15:42 | 显示全部楼层
已经可以正常启动了,但是还有疑问,详情见 https://bbs.21ic.com/forum.php?mod=redirect&goto=findpost&pt ...
好的,我帮你看一下哈~~
该帖问题已经解决的话,麻烦帮忙结帖哈,非常感谢~~
评分
参与人数 1威望 +1 收起 理由
sulinux + 1 很给力!
查看全部评分
