[DemoCode下载] M051库函数分析GPIO
10459|53
gaoyang9992006 发表于 2015-1-13 22:36 | 显示全部楼层
下面给出一个应用例子。
    /* GPIO Interrupt Function Test        */
    printf("P1.3 and P4.5 are used to test interrupt ......\n");
    /* Configure P1.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(P1, BIT3, GPIO_PMD_INPUT);
    GPIO_EnableInt(P1, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPIO_P0P1_IRQn);
    /*  Configure P4.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(P4, BIT5, GPIO_PMD_QUASI);
    GPIO_EnableInt(P4, 5, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO_P2P3P4_IRQn);
    /* Waiting for interrupts */
不难发现一共三条语句:1,设置IO工作模式,2,使能对应的中断类型,3,设置中断请求。
另外注意到:嵌套向量中断控制器:Nested Vectored Interrupt Controller (NVIC)
gaoyang9992006 发表于 2015-1-13 22:37 | 显示全部楼层
我们只是不知道第三条中断求求参量代表什么,我们看头文件。
* @brief       Port0/Port1 IRQ
* @param       None
* @return      None
* @details     The Port0/Port1 default IRQ, declared in startup_M051Series.s.
void GPIOP0P1_IRQHandler(void)
    /* To check if P1.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P1, BIT3))
        GPIO_CLR_INT_FLAG(P1, BIT3);
        printf("P1.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
        P0->ISRC = P0->ISRC;
        P1->ISRC = P1->ISRC;
        printf("Un-expected interrupts.\n");
* @brief       Port2/Port3/Port4 IRQ
* @param       None
* @return      None
* @details     The Port2/Port3/Port4 default IRQ, declared in startup_M051Series.s.
void GPIOP2P3P4_IRQHandler(void)
    /* To check if P4.5 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P4, BIT5))
        GPIO_CLR_INT_FLAG(P4, BIT5);
        printf("P4.5 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
        P2->ISRC = P2->ISRC;
        P3->ISRC = P3->ISRC;
        P4->ISRC = P4->ISRC;
gaoyang9992006 发表于 2015-1-13 22:46 | 显示全部楼层
第一部分,检查1.3管脚中断是否发生,如果发生,则执行后面对应的指令。(清楚中断标志位,打印该端口发生中断的信息)
第二部分,中断没有发生,     /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
没有发生预期的中断事件,则清楚所有的PORT0.PORT1的中断。
另外我们看到一个有趣的事情: P0->ISRC = P0->ISRC;
该指令读取对应的Interrupt Source Flag(ISRC)中断源标志位,然后重写。其实就是没有中断发生,该标志位为0,读出来还写回去,相当于什么都没干。:lol本人这么理解肯定不太对。求高手分析。
最后打印出来没有发生该位置中断的信息。
 楼主| mintspring 发表于 2015-1-18 13:31 | 显示全部楼层
第一部分,检查1.3管脚中断是否发生,如果发生,则执行后面对 ...
讲解的很到位,Interrupt Source Flag(ISRC)中断源标志位,这个意思不理解真会糊涂的
 楼主| mintspring 发表于 2015-1-18 13:32 | 显示全部楼层
下面给出一个应用例子。
以前不懂这个意思,谢谢,看来手册要认真看才行。
zxf0168 发表于 2015-1-22 14:15 | 显示全部楼层
gaoyang9992006 发表于 2015-1-13 21:44
你从哪里复制粘贴来的?
zxf0168 发表于 2015-1-22 14:16 | 显示全部楼层
gaoyang9992006 发表于 2015-1-13 21:48
咱们来总结一下,IO口可以通过库函数设置哪些模式:
4种 I/O 模式:
复制粘贴来的东西:funk:
gaoyang9992006 发表于 2015-1-22 14:16 | 显示全部楼层
你从哪里复制粘贴来的?
复制的库函数,我加以讲解,IAR里面的。
zxf0168 发表于 2015-1-22 14:17 | 显示全部楼层
gaoyang9992006 发表于 2015-1-13 22:20
中断类型共五种,对应上面的:
低电平触发,高电平触发,
下降沿触发,上升沿触发,上升和下降沿触发。 ...
最基础的东西:L
gaoyang9992006 发表于 2015-1-22 14:17 | 显示全部楼层
复制粘贴来的东西
不是的,我自己敲上去的,你个傻鸟看清楚了,那可是汉字,原版的就是英文版库函数.h文件。我复制一段,讲解一段
gaoyang9992006 发表于 2015-1-22 14:18 | 显示全部楼层
最基础的东西
你会吗?
zxf0168 发表于 2015-1-23 09:45 | 显示全部楼层
你会吗?
最基础的东西,我不会
gaoyang9992006 发表于 2015-1-23 19:16 | 显示全部楼层
最基础的东西,我不会
你这,气人。
 楼主| mintspring 发表于 2015-1-27 00:06 来自手机 | 显示全部楼层
好多缩写要看手册
