[DemoCode下载] 一个例子说明M051的GPIO库函数的特点
4312|3
 楼主| gaoyang9992006 发表于 2015-1-13 22:49 | 显示全部楼层 |阅读模式
* @file     main.c
* @version  V3.00
* $Revision: 3 $
* $Date: 14/01/28 11:44a $
* @brief    M051 Series GPIO Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    int32_t i32Err;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------+\n");
    printf("|    P1.2(Output) and P4.1(Input) Sample Code     |\n");
    printf("+-------------------------------------------------+\n\n");
    /* Configure P1.2 as Output mode and P4.1 as Input mode */
    GPIO_SetMode(P1, BIT2, GPIO_PMD_OUTPUT);
    GPIO_SetMode(P4, BIT1, GPIO_PMD_INPUT);
    i32Err = 0;
    printf("GPIO P1.2(output mode) connect to P4.1(input mode) ......");
    /* Use Pin Data Input/Output Control to pull specified I/O or get I/O pin status */
    P12 = 0;
    if(P41 != 0)
        i32Err = 1;
    P12 = 1;
    if(P41 != 1)
        i32Err = 1;
    if(i32Err)
        printf("  [FAIL].\n");
    else
        printf("  [OK].\n");
    /* Configure P1.2 and P4.1 to default Quasi-bidirectional mode */
    GPIO_SetMode(P1, BIT2, GPIO_PMD_QUASI);
    GPIO_SetMode(P4, BIT1, GPIO_PMD_QUASI);
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
 楼主| gaoyang9992006 发表于 2015-1-13 22:52 | 显示全部楼层
我们发现跟IO有关的是下面的这几句。我们分析一下,
    i32Err = 0;
   P12 = 0;
    if(P41 != 0)
        i32Err = 1;
    P12 = 1;
    if(P41 != 1)
        i32Err = 1;
    if(i32Err)
    else
        printf("  [OK].\n");
 楼主| gaoyang9992006 发表于 2015-1-13 22:56 | 显示全部楼层
观察上面凸显的语句,然后我们从库函数里找到出处。
#define GPIO_PIN_ADDR(port, pin)    (*((volatile uint32_t *)((GPIO_PIN_DATA_BASE+(0x20*(port))) + ((pin)<<2))))
#define P12             GPIO_PIN_ADDR(1, 2) /*!< Specify P12 Pin Data Input/Output */
#define P41             GPIO_PIN_ADDR(4, 1) /*!< Specify P41 Pin Data Input/Output */
这是关于两个管脚端口的定义。都是通过宏实现了间接的对位操作。
GPIO_SetMode(P1, BIT2, GPIO_PMD_OUTPUT);设置P1.2为输出模式
  GPIO_SetMode(P1, BIT2, GPIO_PMD_QUASI);设置P1.2为准双向模式
 楼主| gaoyang9992006 发表于 2015-1-13 22:58 | 显示全部楼层
每个例子都有以下内容开头。
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
在该例程的文件里并没有出现,那么就是头文件里的内容,且是#include "M051Series.h"头文件内容。
所以不用深究
2052
