[Atmel] 用ASF跑SAMD21程序(20)WDT POLLED
1290|0
 楼主| ddllxxrr 发表于 2015-1-20 14:11 | 显示全部楼层 |阅读模式
那个polled我查了下字典是:剪去毛的; 无角的; 截角的; 截去树梢的
现在就记住它不是回调的函数,且特别简单的程序好了。
首先选择:新建ASF工程,在ASF向导里加WDT(POLLED)模块。然后APPLY
在ASF EXPLORER中点开QUICK START GUIDE
按照指导上说的,完成程序。注意这个时钟用到 GCLK generator 4
得把 GCLK generator 4 设为使能。
  1. /* Configure GCLK generator 4 */
  2. #  define CONF_CLOCK_GCLK_4_ENABLE                true
  3. #  define CONF_CLOCK_GCLK_4_RUN_IN_STANDBY        false
  4. #  define CONF_CLOCK_GCLK_4_CLOCK_SOURCE          GCLK_SOURCE_OSCULP32K
  5. #  define CONF_CLOCK_GCLK_4_PRESCALER             1
  6. #  define CONF_CLOCK_GCLK_4_OUTPUT_ENABLE         false
然后编译编译通过后,一按复位键小灯闪一下。
  1. /**
  2. * \file
  3. *
  4. * \brief Empty user application template
  5. *
  6. */
  7. /**
  8. * \mainpage User Application template doxygen documentation
  9. *
  10. * \par Empty user application template
  11. *
  12. * This is a bare minimum user application template.
  13. *
  14. * For documentation of the board, go \ref group_common_boards "here" for a link
  15. * to the board-specific documentation.
  16. *
  17. * \par Content
  18. *
  19. * -# Include the ASF header files (through asf.h)
  20. * -# Minimal main function that starts with a call to system_init()
  21. * -# Basic usage of on-board LED and button
  22. * -# "Insert application code here" comment
  23. *
  24. */
  25. /*
  26. * Include header files for all drivers that have been imported from
  27. * Atmel Software Framework (ASF).
  28. */
  29. void configure_wdt(void);
  30. #include <asf.h>
  31. void configure_wdt(void)
  32. {
  33.     /* Create a new configuration structure for the Watchdog settings and fill
  34.      * with the default module settings. */
  35.     struct wdt_conf config_wdt;
  36.     wdt_get_config_defaults(&config_wdt);
  37.     /* Set the Watchdog configuration settings */
  38.     config_wdt.always_on      = false;
  39.     config_wdt.clock_source   = GCLK_GENERATOR_4;
  40.     config_wdt.timeout_period = WDT_PERIOD_2048CLK;
  41.     /* Initialize and enable the Watchdog with the user settings */
  42.     wdt_set_config(&config_wdt);
  43. }
  44. int main (void)
  45. {
  46.         system_init();
  47.         configure_wdt();
  48.          enum system_reset_cause reset_cause = system_get_reset_cause();
  49.          if (reset_cause == SYSTEM_RESET_CAUSE_WDT) {
  50.                  port_pin_set_output_level(LED_0_PIN, LED_0_INACTIVE);
  51.          }
  52.          else {
  53.                  port_pin_set_output_level(LED_0_PIN, LED_0_ACTIVE);
  54.          }
  55.          while (true) {
  56.                  if (port_pin_get_input_level(BUTTON_0_PIN) == false) {
  57.                          port_pin_set_output_level(LED_0_PIN, LED_0_ACTIVE);
  58.                          wdt_reset_count();
  59.                  }
  60.          }
  61. }
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
