[Atmel] Atmel MSL3080 LED 驱动芯片
781|0
 楼主| ddllxxrr 发表于 2015-1-21 21:53 | 显示全部楼层 |阅读模式
The MSL3080 8-channel LED drivers with integrated boost regulator controller offers a complete solution to drive parallel LED strings at up to 40V. The LED current sinks control up to 60mA each for up to 19W of LED power. The MSL3080 has eight current sinks. Parallel connect the current sinks for increased string current. A single resistor sets LED current, with string matching and accuracy within ±3%.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
