关于合众达DM642灰度均衡化的例程
1466|4
 楼主| lbn321 发表于 2015-1-24 14:57 | 显示全部楼层 |阅读模式
我用合众达DM642灰度均衡化的例程跑出来的图像全部花掉了。
但是我把图像均衡化的函数注释掉的话,是可以正常显示的。
以下是该例程的代码,有用过合众达的朋友帮帮忙。谢谢啦~!
/*  Copyright 2004 by SEED Incorporated.                                                        */
/*  All rights reserved. Property of SEED Incorporated.                                */
/*  Restricted rights to use, duplicate or disclose this code are        */
/*  granted through contract.        */
/*                          »Ò¶È¾ùºâ                                */
#include <csl.h>
#include <csl_emifa.h>
#include <csl_i2c.h>
#include <csl_gpio.h>
#include <csl_irq.h>
#include <csl_chip.h>
#include <csl_dat.h>
#include "iic.h"
#include "vportcap.h"
#include "vportdis.h"
#include "sa7121h.h"
#include "TVP51xx.h"
/*SEEDDM642µÄemifaµÄÉèÖýṹ*/
EMIFA_Config Seeddm642ConfigA ={
           0x00052078,/*gblctl EMIFA(B)global control register value */
                                     /*½«CLK6¡¢4¡¢1ʹÄÜ£»½«MRMODEÖÃ1£»Ê¹ÄÜEK2EN,EK2RATE*/
           0xffffffd3,/*cectl0 CE0 space control register value*/
                                     /*½«CE0¿Õ¼äÉèΪSDRAM*/
           0x73a28e01,/*cectl1 CE1 space control register value*/
                                     /*Read hold: 1 clock;
                                       MTYPE : 0000,Ñ¡Ôñ8λµÄÒì²½½Ó¿Ú
                                       Read strobe £º001110£»14¸öclock¿í¶È
                                       TA£º2 clock; Read setup 2 clock;
                                       Write hold :2 clock; Write strobe: 14 clock
                                       Write setup :7 clock
                                               \                 14c                /1c
           0x22a28a22, /*cectl2 CE2 space control register value*/
       0x22a28a42, /*cectl3 CE3 space control register value*/
           0x57115000, /*sdctl SDRAM control register value*/
           0x0000081b, /*sdtim SDRAM timing register value*/
           0x001faf4d, /*sdext SDRAM extension register value*/
           0x00000002, /*cesec0 CE0 space secondary control register value*/
           0x00000002, /*cesec1 CE1 space secondary control register value*/
           0x00000002, /*cesec2 CE2 space secondary control register value*/
           0x00000073 /*cesec3 CE3 space secondary control register value*/
/*SEEDDM642µÄIICµÄÉèÖýṹ*/
I2C_Config SEEDDM642IIC_Config = {
    0,  /* master mode,  i2coar;²ÉÓÃÖ÷ģʽ   */
    0,  /* no interrupt, i2cimr;ֻд£¬²»¶Á£¬²ÉÓÃÎÞÖжϷ½Ê½*/
    (20-5), /* scl low time, i2cclkl;  */
    (20-5), /* scl high time,i2cclkh;  */
    1,  /* configure later, i2ccnt;*/
    0,  /* configure later, i2csar;*/
    0x4ea0, /* master tx mode,     */
            /* i2c runs free,      */
            /* 8-bit data + NACK   */
            /* no repeat mode      */
    (75-1), /* 4MHz clock, i2cpsc  */
CHIP_Config SEEDDM642percfg = {
        CHIP_VP2+\
        CHIP_VP1+\
        CHIP_VP0+\
        CHIP_I2C
I2C_Handle hSeeddm642i2c;
int portNumber;
extern SA7121H_ConfParams sa7121hPAL[45];
extern SA7121H_ConfParams sa7121hNTSC[45];
Uint8 vFromat = 0;
Uint8 misc_ctrl = 0x6D;
Uint8 output_format = 0x47;
// µØÖ·Îª0 for cvbs port1,Ñ¡Ôñ¸´ºÏÐźÅ×öΪÊäÈë
Uint8 input_sel = 0x00;
/*µØÖ·Îª0xf£¬½«Pin27ÉèÖóÉΪCAPEN¹¦ÄÜ*/
Uint8 pin_cfg = 0x02;
/*µØÖ·Îª1B*/
Uint8 chro_ctrl_2 = 0x14;
/*ͼÏñ¾ä±úµÄÉùÃ÷*/
VP_Handle vpHchannel0;
VP_Handle vpHchannel1;
VP_Handle vpHchannel2;
/*È·¶¨Í¼ÏñµÄ²ÎÊý*/
int numPixels = 720;//ÿÐÐ720¸öÏñËØ
int numLines  = 576;//ÿ֡576ÐУ¨PAL£©
/*È·¶¨´¦ÀíµÄ·¶Î§*/
/*A             */
/*             D*/
int intAPixels = 190;
int intALines = 59;
int intDPixels = 530;
int intDLines = 229;
/*****»­¾ØÐα߿òº¯ÊýµÄÉùÃ÷*****/
void drawRectangle();
/*****½øÐлҶȾùºâ´¦Àí*********/
void inteEqualize();
/*²É¼¯ÓëÏÔʾ»º³åÇøµÄÊ×Ö·*/
Uint32 capYbuffer  = 0x80000000;
Uint32 capCbbuffer = 0x800675c0;
Uint32 capCrbuffer = 0x8009b0a0;
Uint32 disYbuffer  = 0x80100000;
Uint32 disCbbuffer = 0x801675c0;
Uint32 disCrbuffer = 0x8019b0a0;
Uint32 tempYbuffer    = 0x80200000;   //ÁÙʱ
/*ͼÏñ¸ñʽ±êÖ¾*/
Uint8 NTSCorPAL = 0;
extern far void vectors();
extern volatile Uint32 capNewFrame;
extern volatile Uint32 disNewFrame;
/*´Ë³ÌÐò¿É½«Ëĸö²É¼¯¿ÚµÄÊý¾Ý¾­¹ýVideo Port0Ëͳö*/
void main()
        Uint8 addrI2C;
        int i;
/* perform all initializations                           */
        /*Initialise CSL£¬³õʼ»¯CSL¿â*/
        CSL_init();
        CHIP_config(&SEEDDM642percfg);
        /*EMIFAµÄ³õʼ»¯£¬½«CE0ÉèΪSDRAM¿Õ¼ä£¬CE1ÉèΪÒì²½¿Õ¼ä
         ×¢£¬DM642Ö§³ÖµÄÊÇEMIFA£¬¶ø·ÇEMIF*/
        EMIFA_config(&Seeddm642ConfigA);
        /*ÖжÏÏòÁ¿±íµÄ³õʼ»¯*/
        //Point to the IRQ vector table
    IRQ_setVecs(vectors);
    IRQ_nmiEnable();
    IRQ_globalEnable();
    IRQ_map(IRQ_EVT_VINT1, 11);
    IRQ_map(IRQ_EVT_VINT0, 12);
    IRQ_reset(IRQ_EVT_VINT1);
    /*´ò¿ªÒ»¸öÊý¾Ý¿½±´µÄÊý¾Ýͨ·*/
    DAT_open(DAT_CHAANY, DAT_PRI_LOW, DAT_OPEN_2D);
        /*½øÐÐIICµÄ³õʼ»¯*/
        hSeeddm642i2c = I2C_open(I2C_PORT0,I2C_OPEN_RESET);
        I2C_config(hSeeddm642i2c,&SEEDDM642IIC_Config);
        /*½øÐÐTVP5150pbsµÄ³õʼ»¯*/
        /*Ñ¡ÔñTVP5150£¬ÉèÖõÚÈýͨ·*/
        GPIO_RSET(GPGC,0x0);/*½«GPIO0²»×öΪGPINTʹÓÃ*/
        GPIO_RSET(GPDIR,0x1);/*½«GPIO0×öΪÊä³ö*/
        GPIO_RSET(GPVAL,0x0);/*GPIO0Êä³öΪ¸ß£¬Ñ¡ÔñIIC1×ÜÏߣ¬ÅäÖÃ
                                                   µÚ¶þ·£¬¼´ÎªU21*/
        addrI2C = 0xBA >>1;
    _IIC_write(hSeeddm642i2c, addrI2C,0x00, input_sel);
    _IIC_write(hSeeddm642i2c, addrI2C,0x03, misc_ctrl);
    _IIC_write(hSeeddm642i2c, addrI2C,0x0D, output_format);
    _IIC_write(hSeeddm642i2c, addrI2C,0x0F, pin_cfg);
    _IIC_write(hSeeddm642i2c, addrI2C,0x1B, chro_ctrl_2);
    /*»Ø¶Áµ±Ç°ÉãÏñÉ豸µÄ¸ñʽ*/
    _IIC_read(hSeeddm642i2c, addrI2C,0x8c, &vFromat);
    vFromat = vFromat & 0xff;
        switch (vFromat)
                case TVP51XX_NTSCM:
                case TVP51XX_NTSC443:
                        NTSCorPAL = 1;/*ϵͳΪNTSCµÄģʽ*/
                        break;
                case TVP51XX_PALBGHIN:
                case TVP51XX_PALM:
                        NTSCorPAL = 0;/*ϵͳΪPALµÄģʽ*/
                        break;
                default:
                        NTSCorPAL = 2;/*ϵͳΪ²»Ö§³ÖµÄģʽ*/
                        break;
        if(NTSCorPAL ==2)
                /*ϵͳ²»Ö§³ÖµÄģʽ£¬ÖØÐÂÅäÖÃ*/
                for(;;)
        /*½øÐÐSAA7121HµÄ³õʼ»¯*/
        GPIO_RSET(GPVAL,0x0);/*GPIO0Êä³öΪµÍ£¬Ñ¡ÔñIIC1×ÜÏߣ¬ÅäÖÃͼÏñÊä³ö*/
        addrI2C = 0xB8 >>1; /*Ñ¡ÔñµÚ0·µÄI2CµÄµØÖ·*/
        /*½«µÚ0·µÄÊÓÆµÊäÈë¿ÚµÄÊý¾Ý¿ÚÉèΪ¸ß×è״̬£¬
          Ê¹ÄÜSCLK£¬½«µÚ27½ÅÉèΪÊäÈë*/
        _IIC_write(hSeeddm642i2c, addrI2C,0x03, 0x1);
        /*ÅäÖÃSAA7121H*/
        GPIO_RSET(GPVAL,0x1);/*GPIO0Êä³öΪµÍ£¬Ñ¡ÔñIIC1×ÜÏߣ¬ÅäÖÃͼÏñÊä³ö*/
        /*³õʼ»¯Video Port0*/
        /*½«Vedio Port1ÉèΪencoderÊä³ö*/
        portNumber = 0;
        vpHchannel0 = bt656_8bit_ncfd(portNumber);
        addrI2C = 0x88 >>1;
        for(i =0; i<43; i++)
                if(NTSCorPAL == 1)
                                           addrI2C,
                                           (sa7121hNTSC[i].regsubaddr),
                                           (sa7121hNTSC[i].regvule));
                else
                                           addrI2C,
                                           (sa7121hPAL[i].regsubaddr),
                                           (sa7121hPAL[i].regvule));
        /*³õʼ»¯Video Port1*/
        /*½«Vedio Port1ÉèΪ²É¼¯ÊäÈë*/
        portNumber = 1;
        vpHchannel1 = bt656_8bit_ncfc(portNumber);
        bt656_capture_start(vpHchannel1);
        /*µÈ´ýµÚÒ»Ö¡Êý¾Ý²É¼¯Íê³É*/
        while(capNewFrame == 0){}
        /*½«Êý¾Ý´æÈëÏÔʾ»º³åÇø£¬²¢Çå²É¼¯Íê³ÉµÄ±êÖ¾*/
        capNewFrame =0;
        for(i=0;i<numLines;i++)
                /*´«ËÍÁÙʱY»º³åÇø*/
                DAT_copy((void *)(capYbuffer + i * numPixels),
                     (void *)(tempYbuffer + i * numPixels),
                     numPixels);
    /*»­±ß¿ò*/
    drawRectangle();
        /*½øÐлҶȾùºâ´¦Àí*/
        inteEqualize();
//        inteEqualizeLai();
        for(i=0;i<0x33ae0;i++)
            *((Uint8 *)(disCrbuffer +i)) =0x80;
            *((Uint8 *)(disCbbuffer +i)) =0x80;
                /*´«ËÍY»º³åÇø*/
                DAT_copy((void *)(tempYbuffer + i * numPixels),
                    (void *)(disYbuffer + i * numPixels),
                     numPixels);
        /*Æô¶¯ÏÔʾģ¿é*/
        bt656_display_start(vpHchannel0);
        /*½¨Á¢ÏÔʾµÄʵʱѭ»·*/
        for(;;)
                /*µ±²É¼¯ÇøµÄÊý¾ÝÒѾ­²É¼¯ºÃ£¬¶øÏÔʾ»º³åÇøµÄÊý¾ÝÒÑ¿Õ*/
                if((capNewFrame == 1)&&(disNewFrame == 1))
                        /*½«Êý¾Ý×°ÈëÏÔʾ»º³åÇø£¬²¢Çå²É¼¯Íê³ÉµÄ±êÖ¾*/
                        capNewFrame =0;
                        disNewFrame =0;
                                /*´«ËÍÁÙʱY»º³åÇø*/
                                     numPixels);
                    /*»­±ß¿ò*/
                    drawRectangle();
                        /*½øÐлҶȾùºâ´¦Àí*/
                        inteEqualize();
                                /*´«ËÍY»º³åÇø*/
                                     numPixels);
        for(;;)
        /*²É¼¯Óë»Ø·Å*/
/*»­¾ØÐα߿òº¯ÊýµÄ¶¨Òå*/
    int i,j;
    /*»­Éϱß*/
    //ÆæÊýÐÐ
    for(i=intALines-4;i<intALines;i++)
            for(j=intAPixels-6;j<intDPixels+6;j++)
                     *(Uint8 *)(tempYbuffer + i*numPixels + j) = 0x00;
        //żÊýÐÐ
        for(i=numLines/2+intALines-4;i<numLines/2+intALines;i++)
        /*»­Ï±ß*/
        //ÆæÊýÐÐ
    for(i=intDLines;i<intDLines+4;i++)
        //żÊýÐÐ
        for(i=numLines/2+intDLines;i<numLines/2+intDLines+4;i++)
        /*»­×ó±ß*/
        //ÆæÊýÐÐ
    for(i=intALines;i<intDLines;i++)
            for(j=intAPixels-6;j<intAPixels;j++)
        //żÊýÐÐ
        for(i=numLines/2+intALines;i<numLines/2+intDLines;i++)
        /*»­ÓÒ±ß*/
        //ÆæÊýÐÐ
            for(j=intDPixels;j<intDPixels+6;j++)
        //żÊýÐÐ
/*½øÐлҶȾùºâ´¦Àí*/
void inteEqualize()
        int i,j,intTemp;
        int intArea = (intDPixels-intAPixels)*(intDLines-intALines)*2;  //Ãæ»ý£¨×ܵÄÏñËØ£©
        Uint8 grayMap[256];  //»Ò¶ÈÓ³Éä±í
        int intCount[256];   //µÚi¼¶»Ò¶È¼ÆÊý
        /*ÖØÖüÆÊýΪ0*/
        for(i=0;i<256;i++)
                //ÇåÁã
                intCount[i]=0;
        /*¼ÆËã¸÷¸ö»Ò¶ÈÖµµÃ¼ÆÊý*/
        //·½¿òÄÚÆæÊýÐÐ
            for(j=intAPixels;j<intDPixels;j++)
            intTemp = *(Uint8 *)(tempYbuffer + i*numPixels + j);
                    //¼ÆÊý¼Ó1
                    intCount[intTemp]++;
        //·½¿òÄÚżÊýÐÐ
                    //¼ÆÊý¼Ó1
        /*¼ÆËã»Ò¶ÈÓ³Éä±í*/
        for(i=0;i<256;i++)
                //³õʼ»¯Îª0
                intTemp = 0;
                for(j=0;j<=i;j++)
                        intTemp+=intCount[j];
                //¼ÆËã¶ÔÓ¦µÄлҶÈÖµ
                grayMap[i] = (Uint8)(intTemp*255/intArea);
        /*½øÐлҶȾùºâ£¬ÖØÐ¸³Öµ*/
        //·½¿òÄÚÆæÊýÐÐ
                    //¸³ÐµĻҶÈÖµ
                    *(Uint8 *)(tempYbuffer + i*numPixels + j) = grayMap[intTemp];
        //·½¿òÄÚżÊýÐÐ
                    //¸³ÐµĻҶÈÖµ
inteEqualizeLai()
        int i,j,intTemp;
        long pixelNum = (intDPixels-intAPixels)*(intDLines-intALines)*2;  //Ãæ»ý£¨×ܵÄÏñËØ£©
        long hist[256];
        long nNum = 0;
        double pr;
        //Uint8 grayMap[256];  //»Ò¶ÈÓ³Éä±í
        //int intCount[256];   //µÚi¼¶»Ò¶È¼ÆÊý
        /*ÖØÖüÆÊýΪ0*/
        for(i=0;i<256;i++)
                //ÇåÁã
                hist[i]=0;
        //¼ÆËãͼÏñÖ±·½Í¼
        //·½¿òÄÚÆæÊýÐÐ
                    //¼ÆÊý¼Ó1
                    hist[*(Uint8 *)(tempYbuffer + i*numPixels + j)]++;
        //·½¿òÄÚżÊýÐÐ
                    //¼ÆÊý¼Ó1
        /*¼ÆËã±ä»»ºóµÄ»Ò¶ÈÖµ*/
        for(i=0;i<256;i++)
                nNum += hist[i];
                pr = (double)nNum/pixelNum;
                hist[i] = (Uint8)255*pr;
        //·½¿òÄÚÆæÊýÐÐ
                    //¸³ÐµĻҶÈÖµ
                    *(Uint8 *)(tempYbuffer + i*numPixels + j) = hist[*(Uint8 *)(tempYbuffer + i*numPixels + j)];
        //·½¿òÄÚżÊýÐÐ
                    //¸³ÐµĻҶÈÖµ
angerbird 发表于 2015-1-25 21:47 | 显示全部楼层
参考了啊,,这个里程很有学习的价值的。
 楼主| lbn321 发表于 2015-1-26 09:25 | 显示全部楼层
参考了啊,,这个里程很有学习的价值的。
你那里可以跑出来吗,请问?
小木欧尼 发表于 2015-1-28 22:34 | 显示全部楼层
没玩过  谢谢分享
 楼主| lbn321 发表于 2015-2-2 11:07 | 显示全部楼层
难道没人也用过吗
