[ARM9、LPC] 如何设置AT91SAM9G20的PIT中断
1088|0
 楼主| BrilliantDT 发表于 2015-4-22 21:34 | 显示全部楼层 |阅读模式
at91, pi, sam, TI, se
麻烦大家看一下,我的代码如下,我想在PIT中断服务程序中从串口发送一个字节,并让LED灯闪烁。可Main函数好像一执行到MyPrvSetupTimerInterrupt就有问题,即无法响应中断服务程序,也无法进入Main函数的for循环中,问题出在哪?麻烦各位的解答了!
int main()
    LED_Configure(0);
    LED_Configure(1);
    PIO_Configure(pins, PIO_LISTSIZE(pins));
    ConfigureUsart0();
    USART_Write(AT91C_BASE_US0, 0x11, 0);
    MyPrvSetupTimerInterrupt();
    for( ;; )
          USART_Write(AT91C_BASE_US0, 0x10, 0);
static void MyPortTickISR( void )
volatile unsigned long ulDummy;
        USART_Write(AT91C_BASE_US0, 0x00, 0);
        ul3++;
        if(ul3 <= 500)
          LED1_ON;
        else if (ul3 > 500 && ul3<=1000)
          LED1_OFF;
        else
          ul3=0;
        /* Clear the PIT interrupt. */
        ulDummy = AT91C_BASE_PITC->PITC_PIVR;
        /* To remove compiler warning. */
        ( void ) ulDummy;
static void MyPrvSetupTimerInterrupt( void )
const unsigned long ulPeriodIn_uS = ( 1.0 / ( double ) configTICK_RATE_HZ ) * port1SECOND_IN_uS;
        /* Setup the PIT for the required frequency. */
        PIT_Init( ulPeriodIn_uS, BOARD_MCK / port1MHz_IN_Hz );
        /* Setup the PIT interrupt. */
        AIC_DisableIT( AT91C_ID_SYS );
        AIC_ConfigureIT( AT91C_ID_SYS, AT91C_AIC_PRIOR_LOWEST, MyPortTickISR );
        AIC_EnableIT( AT91C_ID_SYS );
        PIT_EnableIT();
