小弟有一个S3C2410的地址h文件,内部有一地方写道: // USB DEVICE #ifdef __BIG_ENDIAN <ERROR IF BIG_ENDIAN> #define rFUNC_ADDR_REG (*(volatile unsigned char *)0x52000143) //Function address #define rPWR_REG (*(volatile unsigned char *)0x52000147) //Power management #define rEP_INT_REG (*(volatile unsigned char *)0x5200014b) //EP Interrupt pending and clear #define rUSB_INT_REG (*(volatile unsigned char *)0x5200015b) //USB Interrupt pending and clear #define rEP_INT_EN_REG (*(volatile unsigned char *)0x5200015f) //Interrupt enable #define rUSB_INT_EN_REG (*(volatile unsigned char *)0x5200016f) #define rFRAME_NUM1_REG (*(volatile unsigned char *)0x52000173) //Frame number lower byte #define rFRAME_NUM2_REG (*(volatile unsigned char *)0x52000177) //Frame number higher byte #define rINDEX_REG (*(volatile unsigned char *)0x5200017b) //Register index #define rMAXP_REG (*(volatile unsigned char *)0x52000183) //Endpoint max packet #define rEP0_CSR (*(volatile unsigned char *)0x52000187) //Endpoint 0 status #define rIN_CSR1_REG (*(volatile unsigned char *)0x52000187) //In endpoint control status #define rIN_CSR2_REG (*(volatile unsigned char *)0x5200018b) #define rOUT_CSR1_REG (*(volatile unsigned char *)0x52000193) //Out endpoint control status #define rOUT_CSR2_REG (*(volatile unsigned char *)0x52000197) #define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x5200019b) //Endpoint out write count #define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019f) #define rEP0_FIFO (*(volatile unsigned char *)0x520001c3) //Endpoint 0 FIFO #define rEP1_FIFO (*(volatile unsigned char *)0x520001c7) //Endpoint 1 FIFO #define rEP2_FIFO (*(volatile unsigned char *)0x520001cb) //Endpoint 2 FIFO #define rEP3_FIFO (*(volatile unsigned char *)0x520001cf) //Endpoint 3 FIFO #define rEP4_FIFO (*(volatile unsigned char *)0x520001d3) //Endpoint 4 FIFO #define rEP1_DMA_CON (*(volatile unsigned char *)0x52000203) //EP1 DMA interface control #define rEP1_DMA_UNIT (*(volatile unsigned char *)0x52000207) //EP1 DMA Tx unit counter #define rEP1_DMA_FIFO (*(volatile unsigned char *)0x5200020b) //EP1 DMA Tx FIFO counter #define rEP1_DMA_TTC_L (*(volatile unsigned char *)0x5200020f) //EP1 DMA total Tx counter #define rEP1_DMA_TTC_M (*(volatile unsigned char *)0x52000213) #define rEP1_DMA_TTC_H (*(volatile unsigned char *)0x52000217) #define rEP2_DMA_CON (*(volatile unsigned char *)0x5200021b) //EP2 DMA interface control #define rEP2_DMA_UNIT (*(volatile unsigned char *)0x5200021f) //EP2 DMA Tx unit counter #define rEP2_DMA_FIFO (*(volatile unsigned char *)0x52000223) //EP2 DMA Tx FIFO counter #define rEP2_DMA_TTC_L (*(volatile unsigned char *)0x52000227) //EP2 DMA total Tx counter #define rEP2_DMA_TTC_M (*(volatile unsigned char *)0x5200022b) #define rEP2_DMA_TTC_H (*(volatile unsigned char *)0x5200022f) #define rEP3_DMA_CON (*(volatile unsigned char *)0x52000243) //EP3 DMA interface control #define rEP3_DMA_UNIT (*(volatile unsigned char *)0x52000247) //EP3 DMA Tx unit counter #define rEP3_DMA_FIFO (*(volatile unsigned char *)0x5200024b) //EP3 DMA Tx FIFO counter #define rEP3_DMA_TTC_L (*(volatile unsigned char *)0x5200024f) //EP3 DMA total Tx counter #define rEP3_DMA_TTC_M (*(volatile unsigned char *)0x52000253) #define rEP3_DMA_TTC_H (*(volatile unsigned char *)0x52000257) #define rEP4_DMA_CON (*(volatile unsigned char *)0x5200025b) //EP4 DMA interface control #define rEP4_DMA_UNIT (*(volatile unsigned char *)0x5200025f) //EP4 DMA Tx unit counter #define rEP4_DMA_FIFO (*(volatile unsigned char *)0x52000263) //EP4 DMA Tx FIFO counter #define rEP4_DMA_TTC_L (*(volatile unsigned char *)0x52000267) //EP4 DMA total Tx counter #define rEP4_DMA_TTC_M (*(volatile unsigned char *)0x5200026b) #define rEP4_DMA_TTC_H (*(volatile unsigned char *)0x5200026f) #else // Little Endian #define rFUNC_ADDR_REG (*(volatile unsigned char *)0x52000140) //Function address #define rPWR_REG (*(volatile unsigned char *)0x52000144) //Power management #define rEP_INT_REG (*(volatile unsigned char *)0x52000148) //EP Interrupt pending and clear #define rUSB_INT_REG (*(volatile unsigned char *)0x52000158) //USB Interrupt pending and clear #define rEP_INT_EN_REG (*(volatile unsigned char *)0x5200015c) //Interrupt enable #define rUSB_INT_EN_REG (*(volatile unsigned char *)0x5200016c) #define rFRAME_NUM1_REG (*(volatile unsigned char *)0x52000170) //Frame number lower byte #define rFRAME_NUM2_REG (*(volatile unsigned char *)0x52000174) //Frame number higher byte #define rINDEX_REG (*(volatile unsigned char *)0x52000178) //Register index #define rMAXP_REG (*(volatile unsigned char *)0x52000180) //Endpoint max packet #define rEP0_CSR (*(volatile unsigned char *)0x52000184) //Endpoint 0 status #define rIN_CSR1_REG (*(volatile unsigned char *)0x52000184) //In endpoint control status #define rIN_CSR2_REG (*(volatile unsigned char *)0x52000188) #define rOUT_CSR1_REG (*(volatile unsigned char *)0x52000190) //Out endpoint control status #define rOUT_CSR2_REG (*(volatile unsigned char *)0x52000194) #define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x52000198) //Endpoint out write count #define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019c) #define rEP0_FIFO (*(volatile unsigned char *)0x520001c0) //Endpoint 0 FIFO #define rEP1_FIFO (*(volatile unsigned char *)0x520001c4) //Endpoint 1 FIFO #define rEP2_FIFO (*(volatile unsigned char *)0x520001c8) //Endpoint 2 FIFO #define rEP3_FIFO (*(volatile unsigned char *)0x520001cc) //Endpoint 3 FIFO #define rEP4_FIFO (*(volatile unsigned char *)0x520001d0) //Endpoint 4 FIFO #define rEP1_DMA_CON (*(volatile unsigned char *)0x52000200) //EP1 DMA interface control #define rEP1_DMA_UNIT (*(volatile unsigned char *)0x52000204) //EP1 DMA Tx unit counter #define rEP1_DMA_FIFO (*(volatile unsigned char *)0x52000208) //EP1 DMA Tx FIFO counter #define rEP1_DMA_TTC_L (*(volatile unsigned char *)0x5200020c) //EP1 DMA total Tx counter #define rEP1_DMA_TTC_M (*(volatile unsigned char *)0x52000210) #define rEP1_DMA_TTC_H (*(volatile unsigned char *)0x52000214) #define rEP2_DMA_CON (*(volatile unsigned char *)0x52000218) //EP2 DMA interface control #define rEP2_DMA_UNIT (*(volatile unsigned char *)0x5200021c) //EP2 DMA Tx unit counter #define rEP2_DMA_FIFO (*(volatile unsigned char *)0x52000220) //EP2 DMA Tx FIFO counter #define rEP2_DMA_TTC_L (*(volatile unsigned char *)0x52000224) //EP2 DMA total Tx counter #define rEP2_DMA_TTC_M (*(volatile unsigned char *)0x52000228) #define rEP2_DMA_TTC_H (*(volatile unsigned char *)0x5200022c) #define rEP3_DMA_CON (*(volatile unsigned char *)0x52000240) //EP3 DMA interface control #define rEP3_DMA_UNIT (*(volatile unsigned char *)0x52000244) //EP3 DMA Tx unit counter #define rEP3_DMA_FIFO (*(volatile unsigned char *)0x52000248) //EP3 DMA Tx FIFO counter #define rEP3_DMA_TTC_L (*(volatile unsigned char *)0x5200024c) //EP3 DMA total Tx counter #define rEP3_DMA_TTC_M (*(volatile unsigned char *)0x52000250) #define rEP3_DMA_TTC_H (*(volatile unsigned char *)0x52000254) #define rEP4_DMA_CON (*(volatile unsigned char *)0x52000258) //EP4 DMA interface control #define rEP4_DMA_UNIT (*(volatile unsigned char *)0x5200025c) //EP4 DMA Tx unit counter #define rEP4_DMA_FIFO (*(volatile unsigned char *)0x52000260) //EP4 DMA Tx FIFO counter #define rEP4_DMA_TTC_L (*(volatile unsigned char *)0x52000264) //EP4 DMA total Tx counter #define rEP4_DMA_TTC_M (*(volatile unsigned char *)0x52000268) #define rEP4_DMA_TTC_H (*(volatile unsigned char *)0x5200026c) #endif
请问,那个<ERROR IF BIG_ENDIAN>是什么意思?
谢谢! |
