[51单片机] AT24c02读写程序输出到串口的数据总是错误的。
2726|7
 楼主| coolhongjie 发表于 2015-4-26 10:44 | 显示全部楼层 |阅读模式
主要是为了测试IIC总线方式的AT24c02基本读写测试,试了好几次,每次输出到串口的数据都是错误的,把数据输出到led灯也是一样,实在找不出错误。。
main.c的程序
#include "at24c02.h"
void Com_init(void)
        TMOD = 0x20;
        PCON = 0x00;
        TH1 = 0xfd;
        TL1 = 0xfd;
        SCON = 0x40;
        TR1 = 1;
void main(void)
        uchar dat;
        Com_init();
        SCL = 1;
        delay();
        SDA = 1;
        delay();
        send_byte(0x00,0xf0);
        dat = read_byte(0x00);
        while(1)
                SBUF = dat;
                while(!TI);
                TI = 0;
                delay_1ms(1500);
at24c02.c的程序
bit ack_bit = 0;
//-------------------仿真得出延时约为6.51US------------------------
void delay(void)
        _nop_();
        _nop_();
//-------------------非应答信号------------------------
void nack(void)
        SCL = 0;
        delay();
        SDA = 1;
        delay();
        SCL = 1;
        delay();
//-------------------1ms*del延时------------------------
void delay_1ms(uint del)
        uint i,j;
        for(i = 0; i < del; i++)
                for(j = 0; j < 128; j++);
//---------------------start------------------------------
void start(void)
        SDA = 1;                        //SCL高电平期间,SDA由高变低为起始信号
        SCL = 1;
        delay();
        SDA = 0;
        delay();
        SCL = 0;
        delay();
//---------------------stop------------------------------
void stop(void)
        SDA = 0;                        //SCL高电平期间,SDA由低变高为停止信号
        SCL = 1;
        delay();
        SDA = 1;
        delay();
//---------------------send------------------------------
void send(uchar dat)
        uchar i,temp;
        temp = dat;
        SCL = 0;                //SCL拉底,数据可以改变
        delay();
        for(i = 0; i < 8; i++)
                temp <<= 1;                        //temp左移一位
                SDA = CY;                        //CY进位标志的值赋给SDA
                delay();
                SCL = 1;
                delay();
                SCL = 0;
                delay();
        SDA = 1;                        //释放SDA
        delay();
        SCL = 1;                        //高电平,等待应答信号
        delay();
        if(SDA == 1)
                ack_bit = 1;
        else
                ack_bit = 0;
        SDA = 1;
//---------------------read------------------------------
uchar read(void)
        uchar i,dat,j;
        SCL = 0;                        //拉底,为释放SDA做准备
        delay();
        SDA = 1;                        //释放SDA
        delay();
                SCL = 1;                //高电平数据稳定
                delay();
                if(SDA == 1)
                        j = 1;
                else
                        j = 0;
                dat = dat | j;
                delay();
                SCL = 0;                //拉底,为数据改变做准备
                delay();
                dat <<= 1;                //每次左移1位
        SDA = 1;                        //释放总线,等待MCU发送非应答信号
        delay();
        SCL = 1;                        //拉高,数据稳定
        delay();
        return dat;                        //返回dat值
//---------------------send_byte------------------------------
bit send_byte(uchar waddr,uchar dat)        //waddr为子地址的首地址,dat为数据
        start();
        send(0xa0);                //写器件地址,已经说明写位
        if(ack_bit) return 0;
        send(waddr);        //写首地址
        send(dat);                //写数据
        stop();
        delay_1ms(10);
        return 1;
//-------------------read_byte------------------------
uchar read_byte(uchar waddr)
        uchar dat;
        start();
        send(0xa0);                //伪写,目的是写入地址
        send(waddr);        //写首地址
        start();
        send(0xa1);                //写器件地址,读
        dat = read();        //获取数据
        nack();
        stop();
        delay_1ms(10);
        return dat;
下面是串口输出的结果
ayb_ice 发表于 2015-4-26 11:05 | 显示全部楼层
写操作是需要时间的,一般在5~20MS,查具体的芯片手册
ayb_ice 发表于 2015-4-26 11:06 | 显示全部楼层
写操作完成前是不接受新的操作的,包括读也不接受
dirtwillfly 发表于 2015-4-26 23:00 | 显示全部楼层
调试时序最好用个逻辑分析仪看看,会很方便
ningling_21 发表于 2015-4-27 11:31 | 显示全部楼层
I2C的程序,应答处理有点问题
 楼主| coolhongjie 发表于 2015-4-28 10:43 | 显示全部楼层
I2C的程序,应答处理有点问题
能帮我指出来吗??
ningling_21 发表于 2015-4-28 10:49 | 显示全部楼层
能帮我指出来吗??
你先自己判断一下AT24C02器件给应答信号没
