[51单片机] 单片机矩阵按键问题, 求大神
956|6
 楼主| ADC11 发表于 2015-4-26 16:33 | 显示全部楼层 |阅读模式
#include<reg52.h>
  sbit ADDR0 = P1^0;
  sbit ADDR1 = P1^1;
  sbit ADDR2 = P1^2;
  sbit ADDR3 = P1^3;
  sbit ENLED = P1^4;
  sbit KEY_IN_4 = P2^7;
  sbit KEY_IN_3 = P2^6;
  sbit KEY_IN_2 = P2^5;
  sbit KEY_IN_1 = P2^4;
  sbit KEY_OUT_1 = P2^3;
  sbit KEY_OUT_2 = P2^2;
  sbit KEY_OUT_3 = P2^1;
  sbit KEY_OUT_4 = P2^0;
  unsigned char KeySta[4][4]={  {1,1,1,1},
        {1,1,1,1},
        {1,1,1,1},
        {1,1,1,1},
unsigned char code LedChar[]={0xC0, 0xF9, 0xA4, 0xB0, 0x99,
                                                          0x92, 0x82, 0xF8, 0x80, 0x90,
                                                          0x83, 0xC6, 0xA1, 0x86, 0x8E};
void main ()
        unsigned char i,j;         unsigned char backup[4][4]={ {1,1,1,1},
                                                             {1,1,1,1},
                                                           {1,1,1,1},
                                                           {1,1,1,1},
        EA=1;
        ADDR3 = 1;
        ENLED = 0;
        ADDR0 = 0;
        ADDR1 = 0;
        ADDR2 = 0;
        TMOD = 0x01;
        TH0 = 0xFC;
        TL0 = 0x67;
        ET0=1;
        TR0=1;
        P0 = LedChar[0];
        while(1)
                for(i=0;i<4;i++)
                        for(j=0;j<4;j++)
                                if (backup[j] != KeySta[j])
                                        if (backup[j] == 0)
                                                P0 = LedChar[i*4+j];
                                        backup[j] = KeySta[j];
void InterruptTimer0() interrupt 1
        unsigned char i;
        static unsigned        keyout = 0;
        unsigned char keychec[4][4] =   {
        {0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},
       TH0=0xfc;
        TLo=0x67;
        keychec[keyout][0] = (keychec[keyout][0] << 1) | KEY_IN_1;
        keychec[keyout][1] = (keychec[keyout][1] << 1) | KEY_IN_2;
        keychec[keyout][2] = (keychec[keyout][2] << 1) | KEY_IN_3;
        keychec[keyout][3] = (keychec[keyout][3] << 1) | KEY_IN_4;
        for(i=0;i<4;i++)
                if ( (keychec[keyout] & 0x0F) == 0x00)
                        KeySta[keyout] = 0;
                else if ( (keychec[keyout] & 0x0F) == 0x0F)
                        KeySta[keyout] = 1;
        keyout++;
        keyout = (keyout & 0x03);
        switch (keyout)
                case 0 :  KEY_OUT_4 = 1        ;  KEY_OUT_1 = 0 ; break;
                case 1 :  KEY_OUT_1 = 1        ; KEY_OUT_2 = 0 ; break;
                case 2 :  KEY_OUT_2 = 1        ; KEY_OUT_3 = 0 ; break;
                case 3 :  KEY_OUT_3 = 1        ; KEY_OUT_4 = 0 ; break;
                default :break;
 楼主| ADC11 发表于 2015-4-26 16:34 | 显示全部楼层
感觉没问题,下载到单片机里,按键没有反应
 楼主| ADC11 发表于 2015-4-26 16:35 | 显示全部楼层
中断里面不断扫描按键是否按下并消抖,主程序主要对数码管进行更行
 楼主| ADC11 发表于 2015-4-26 16:36 | 显示全部楼层
实在找不出错误,求大神指教,求求求。本人刚学,菜鸟一个
joyme 发表于 2015-4-29 15:44 | 显示全部楼层
                                        if (backup[j] == 0)
定义的是二维数组,怎么能这样比较
luofeng2g 发表于 2015-4-29 16:51 | 显示全部楼层
tanpengjie 发表于 2015-4-30 16:41 | 显示全部楼层
你想要干什么?
