S3C44B0怎么AD转换并LCD输出呢??
2681|5
mxh0506| | 2008-11-4 22:15 | 只看该作者
我这里有一些以前写的ADC的代码,给你参考吧
// ADC ISR
__arm  void  Adc_CompleteISR_Handler (void)
    rI_ISPC = BIT_ADC;       // clear pending bit of adc
    wAdcResult[wAdcPos] = rADCDAT;
    wAdcPos++;
    if(wAdcPos < MAX_ADC_BUFFLEN){
        BSP_ADC_StartChannel(wAdcCh);
    }else{
        OSSemPost(pSemAdc);    // signal sampling over
    Initialize the ADC, dwAdcRate is in Hz
    the larger the PSR is, the lower the input current will be
    so lower ADC rate can lead to more accurate AD result
void BSP_ADC_Init(INT32U dwAdcRate)
    rADCPSR = MCLK/(32*dwAdcRate)-1;
    rADCCON = 0;    // activate ADC clock, no operation, CH0
    pISR_ADC = (unsigned) Adc_CompleteISR_Handler;    // set ISR vector
    rINTMSK &= ~BIT_ADC;    // enable inperrupt
// switch to sepcified channel, and start conversion
// uiChannel must be within 0 to 7
void BSP_ADC_SwitchChannel(INT16U wChannel)
    wAdcPos = 0;
    wAdcCh = wChannel;
    rADCCON = 0x01 | (wChannel << 2);    // start conversion
// start ADC on specified channel
void BSP_ADC_StartChannel(INT16U wChannel)
mxh0506| | 2008-11-4 22:21 | 只看该作者
这个是ADC任务
void TaskSampling(void * pParam)
    INT8U byRet;
    INT16U uiCh;
    OS_CPU_SR  cpu_sr = 0;
    uiCh = 0;
    BSP_ADC_SwitchChannel(uiCh);
    while(1)
        if(pSemAdc){    // semaphore created successfully
            OSTimeDly(5);
            OSSemPend(pSemAdc,0,&byRet);
            if(OS_NO_ERR == byRet){
                wAdc[uiCh] = wAdcResult[2];
                bAdcRdy = 1;
                uiCh++;
                uiCh %= 2;
mxh0506| | 2008-11-4 22:24 | 只看该作者
若再加LCD显示,只需再添加相应的驱动和任务就行了
雅子|  楼主 | 2008-11-12 09:55 | 只看该作者
我参考一下再回复
雅子|  楼主 | 2008-11-13 14:16 | 只看该作者
电路图?
用LPC2124进行AD转换并LCD输出,怎么玩呢???
