arduino 底板采集DHT11温湿度传感器数据,并在1602上显示
2983|3
ruson|  楼主 | 2015-6-20 23:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
机智云的arduino底板,采集DHT11温湿度传感器(机智云的功能板上D3脚,连接至7脚)数据,并在1602上显示。程序如下:
double Fahrenheit(double celsius)
        return 1.8 * celsius + 32;
}    //摄氏温度度转化为华氏温度
double Kelvin(double celsius)
        return celsius + 273.15;
}     //摄氏温度转化为开氏温度
// 露点(点在此温度时,空气饱和并产生露珠)
// 参考: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
        double A0= 373.15/(273.15 + celsius);
        double SUM = -7.90298 * (A0-1);
        SUM += 5.02808 * log10(A0);
        SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
        SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
        SUM += log10(1013.246);
        double VP = pow(10, SUM-3) * humidity;
        double T = log(VP/0.61078);   // temp var
        return (241.88 * T) / (17.558-T);
// 快速计算露点,速度是5倍dewPoint()
// 参考: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
        double a = 17.271;
        double b = 237.7;
        double temp = (a * celsius) / (b + celsius) + log(humidity/100);
        double Td = (b * temp) / (a - temp);
        return Td;
#include <dht11.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);  //定义脚位
dht11 DHT11;
#define DHT11PIN 7
void setup()
  lcd.begin(16,2); //设置LCD显示的数目。16 X 2:16格2行。
  lcd.print("  Hello,21IC!"); //将Hello,21IC!显示在LCD上
  delay(5000);
  Serial.begin(9600);
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
  Serial.println();
void loop()
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case DHTLIB_OK:
                Serial.println("OK");
                break;
    case DHTLIB_ERROR_CHECKSUM:
                Serial.println("Checksum error");
                break;
    case DHTLIB_ERROR_TIMEOUT:
                Serial.println("Time out error");
                break;
    default:
                Serial.println("Unknown error");
                break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, 2);
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
  Serial.print("Temperature (oF): ");
  Serial.println(Fahrenheit(DHT11.temperature), 2);
  Serial.print("Temperature (K): ");
  Serial.println(Kelvin(DHT11.temperature), 2);
  Serial.print("Dew Point (oC): ");
  Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
  Serial.print("Dew PointFast (oC): ");
  Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
  lcd.setCursor(0,0);  //将闪烁的光标设置到column 0, line 1 (注释:从0开始数起,line 0是显示第一行,line 1是第二行。)
  lcd.print("Temp is ");
  lcd.print((float)DHT11.temperature, 2);
  lcd.print(" ");
  lcd.print((char)0xDF);
  lcd.print("C");
  lcd.setCursor(0,1);  //将闪烁的光标设置到column 0, line 1 (注释:从0开始数起,line 0是显示第一行,line 1是第二行。)
  lcd.print("Humi is ");
  lcd.print((float)DHT11.humidity, 2);
  lcd.print(" ");
  lcd.print("%");
  delay(1000);
ruson|  楼主 | 2015-6-20 23:13 | 只看该作者
DATA脚接底板7脚。1602接线与上次相同。
玉杰天| | 2015-6-29 17:47 | 只看该作者
赞一个
解博| | 2015-11-9 21:44 | 只看该作者
:handshake
