[ZLG-ARM]
lpc2366(b版)问题,请就周公
2017|3
xcxxyc|  楼主 | 2007-12-28 09:53 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
xcxxyc|  楼主 | 2007-12-28 17:02 | 显示全部楼层
谢谢zlgarm_wzj。
谢谢,多谢!!
xcxxyc|  楼主 | 2007-12-28 17:10 | 显示全部楼层
这是从LPC2366 的ERRATA上复制下来的
I2S.1:I2S DMA interface is non-operational
Introduction:
   The LPC2366 has an I2S interface, which can be used for audio devices. The I2S interface was initially designed to operate with the general purpose DMA controller.
Problem:
    The DMA controller cannot access the I2S interface.
Workaround:
        No known workaround.
