就是中断方式,Atmel把回调函数替代了以前的中断函数。这样的好处我觉昨不用修改中断那个程序了,只是在程序里声明一下哪个是回调函数就行。
以下是快速指导的提示:
- In this use case, the TC will be used to generate a PWM signal, with a varying duty cycle.
- Here the pulse width is increased each time the timer count matches the set compare value. The TC module will be set up as follows:
- GCLK generator 0 (GCLK main) clock source
- 16-bit resolution on the counter
- No prescaler
- Normal PWM wave generation
- GCLK reload action
- Don't run in standby
- No inversion of waveform output
- No capture enabled
- Count upward
- Don't perform one-shot operations
- No event input enabled
- No event action
- No event generation enabled
- Counter starts on 0
没有什么可以设置的,因为默认就是发生器0
按照提示形成代码。完后编译运行:
- #define PWM_MODULE EXT2_PWM_MODULE
- #define PWM_OUT_PIN EXT2_PWM_0_PIN
- #define PWM_OUT_MUX EXT2_PWM_0_MUX
- Add to the main application source file, outside of any functions:
- struct tc_module tc_instance;
- Copy-paste the following callback function code to your user application:
- void tc_callback_to_change_duty_cycle(
- struct tc_module *const module_inst)
- static uint16_t i = 0;
- i += 128;
- tc_set_compare_value(module_inst, TC_COMPARE_CAPTURE_CHANNEL_0, i + 1);
- Copy-paste the following setup code to your user application:
- void configure_tc(void)
- struct tc_config config_tc;
- tc_get_config_defaults(&config_tc);
- config_tc.counter_size = TC_COUNTER_SIZE_16BIT;
- config_tc.wave_generation = TC_WAVE_GENERATION_NORMAL_PWM;
- config_tc.counter_16_bit.compare_capture_channel[0] = 0xFFFF;
- config_tc.pwm_channel[0].enabled = true;
- config_tc.pwm_channel[0].pin_out = PWM_OUT_PIN;
- config_tc.pwm_channel[0].pin_mux = PWM_OUT_MUX;
- tc_init(&tc_instance, PWM_MODULE, &config_tc);
- tc_enable(&tc_instance);
- void configure_tc_callbacks(void)
- tc_register_callback(
- &tc_instance,
- tc_callback_to_change_duty_cycle,
- TC_CALLBACK_CC_CHANNEL0);
- tc_enable_callback(&tc_instance, TC_CALLBACK_CC_CHANNEL0);
- Add to user application initialization (typically the start of main()):
- configure_tc();
- configure_tc_callbacks();
最后我用一个LED按到了PWM_PUT管脚;
照片及运行效果如下:
http://v.youku.com/v_show/id_XMTI4NjAwMzUyMA==.html?from=y1.7-1.2
