MSP430F149控制NRF905,怎么才能知道数据传输成功没有
996|5
 楼主| Sssss_H 发表于 2015-8-5 20:21 | 显示全部楼层 |阅读模式
我是用开发板上的例程,但是却不知道怎么看出来有没有成功,请问大神们怎么改进
#include <msp430x14x.h>
#define  uchar   unsigned char
#define  uint    unsigned int
#define  uclong  unsigned long
//==================TXEN,TRX_CE,PWR_0 为收发模式控制端口======================
#define  TXEN_0     P6OUT &=~BIT0          //输出0
#define  TXEN_1     P6OUT |= BIT0          //输出1
#define  TRX_CE_0   P6OUT &=~BIT1
#define  TRX_CE_1   P6OUT |= BIT1
#define  PWR_0      P6OUT &=~BIT2
#define  PWR_1      P6OUT |= BIT2
//===================================主入从出===================================
#define  MISO_0     P5OUT &=~BIT2
#define  MISO_1     P5OUT |= BIT2
//==================================主出从入====================================
#define  MOSI_0     P5OUT &=~BIT1
#define  MOSI_1     P5OUT |= BIT1
//===================================SPI时钟端口================================
#define  SCK_0      P5OUT &=~BIT3
#define  SCK_1      P5OUT |= BIT3
//===================================SPI使能端口=================================
#define  CSN_0      P5OUT &=~BIT0
#define  CSN_1      P5OUT |= BIT0
//==================================以下为状态端口==============================
//===========================AM  地址匹配=======================================
#define  AM_0       P6OUT &=~BIT4
#define  AM_1       P6OUT |= BIT4
//=================================DR 数据接收状态==============================
#define  DR_0       P6OUT &=~BIT3
#define  DR_1       P6OUT |= BIT3
//=====================================CD 载波侦听状态==========================
#define  CD_0       P6OUT &=~BIT5
#define  CD_1       P6OUT |= BIT5
#define  LED1_0     P2OUT &=~BIT1          //输出0
#define  LED1_1     P2OUT |= BIT1          //输出1
#define  LED2_0     P2OUT &=~BIT2          //输出0
#define  LED2_1     P2OUT |= BIT2          //输出1
//===========================NRF905:SPI指令=====================================
#define WC                0x00
#define RC                0x10
#define WTP                0x20
#define RTP                0x21
#define WTA                0x22
#define RTA                0x23
#define RRP                0x24
//==========================32字节发送数据收发缓冲区============================
#define TxRxBuf_Len 32
unsigned char TxRxBuf[TxRxBuf_Len]=
{ 0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
  0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,
char TxAddress[4]={0xcc,0xcc,0xcc,0xcc};
char DATA_BUF;
//==========================NRF905:10寄存器配置================================
unsigned char  RFConf[11]=
  WC,                                //SPI写操作命令
  0x4c,                             //CH_NO,配置频段在430MHZ
  0x0C,                             //输出功率为10db,不重发,节电为正常模式
  0x44,                             //地址宽度设置,为4字节
  0x20,0x20,                        //接收发送有效数据长度为32字节
  0xCC,0xCC,0xCC,0xCC,              //接收地址
  0x58,                              //CRC充许,8位CRC校验,外部时钟信号不使能,16M晶振
系统初始化
void InitSys()
   unsigned int iq0;
   _DINT();
   BCSCTL1 &=~XT2OFF;
   do
      IFG1 &= ~OFIFG;                                                        // 清除振荡器失效标志
  for (iq0 = 0xFF; iq0 > 0; iq0--);        // 延时,等待XT2起振
   while ((IFG1 & OFIFG) != 0);                // 判断XT2是否起振
   BCSCTL2 =SELM1+SELS;                      //MCLK,SMCLK时钟为XT2
                                                        //???USART0
//===========================初始化nRF905=======================================
void nRF905_IO_set(void)
        P6DIR |= 0x07; P6DIR &= 0x8F;   P6SEL&=0x84;
        P2DIR |= 0xFF; P2DIR &= 0xFF;   P2SEL&=0xFF;
        P5DIR |= 0xC0; P5DIR |= 0xFB;   P5SEL&=0xF0;
        CSN_1;                                            // Spi         disable
        SCK_0;                                          // Spi clock line init low
        PWR_1;                                         // nRF905 power on
        TRX_CE_0;                                // Set nRF905 in standby mode
        TXEN_0;                                        // set radio in Rx mode
void LED_IO_set(void)
      //  P6DIR |= BIT2;P6OUT |= BIT2;              //关闭电平转换
//==========================延时================================================
void Delay(uchar n)
        uint i;
        while(n--)
        for(i=0;i<80;i++);
//=========================NRF905 SPI读函数(IO模拟SPI时序)==================
unsigned char SpiRead(void)
        unsigned char i;
        for (i=0;i<8;i++)
                DATA_BUF=DATA_BUF<<1;
                SCK_1;
                if ((P5IN&0x04))        //读取最高位,保存至最末尾,通过左移位完成整个字节
                        DATA_BUF|=0x01;
                else
                        DATA_BUF&=~(0x01);
                SCK_0;
         return DATA_BUF;
//=========================NRF905 SPI读写函数(IO模拟SPI时序)==================
void SpiWrite(unsigned char send)
        unsigned char i;
        DATA_BUF=send;
        for (i=0;i<8;i++)
        if (((DATA_BUF&0x80) != 0))        //总是发送最高位
            MOSI_1;
        else
            MOSI_0;
        SCK_1;
        SCK_0;
//==================================初始化NRF905================================
void Config905(void)
        uchar i;
        CSN_0;                                                // Spi enable for write a spi command
        for (i=0;i<11;i++)        // Write configration words  写放配置字
           SpiWrite(RFConf[i]);
        CSN_1;                                        //关闭SPI
//=========================NRF905装载地址+数据打包+数据发送=====================
void TxPacket(void)
        uchar i;
        CSN_0;
        SpiWrite(WTP);                                // 待发数据装载命令
        for (i=0;i<32;i++)
          SpiWrite(TxRxBuf[i]);
        CSN_1;                                  // 关闭SPI
        Delay(1);
        CSN_0;                                        // 打开SPI
        SpiWrite(WTA);                                // 写入地址要和接收方地址一样
        for (i=0;i<4;i++)                        // 4字节地址
          SpiWrite(TxAddress[i]);
        CSN_1;                                        //关闭SPI
        TRX_CE_1;                                        // Set TRX_CE high,start Tx data transmission
        Delay(10);                                        // while (DR!=1);
        TRX_CE_0;                                        // Set TRX_CE low
//==================================发送模式初始化-=============================
void SetTxMode(void)
        TRX_CE_0;
        TXEN_1;
        Delay(1);                                         // Delay for mode change(>=650us)
//==================================数据发送===================================
void TX(void)
        SetTxMode();
        TxPacket();
//==================================主函数=====================================
void main(void)
   WDTCTL = WDTPW + WDTHOLD; //禁止看门狗
   InitSys();
   nRF905_IO_set();
   LED_IO_set();
   Config905();
   LED1_1 ; LED2_1 ;
while(1)
    TX();
    P2OUT=P6OUT;
    Delay(200); Delay(200); Delay(200);LED1_0 ;
    Delay(200); Delay(200); Delay(200); Delay(200); Delay(200); LED1_1;
 楼主| Sssss_H 发表于 2015-8-5 21:19 | 显示全部楼层
求大神
dirtwillfly 发表于 2015-8-5 21:26 | 显示全部楼层
要用两个模块,一个发送一个接收,接收到了就成功了
 楼主| Sssss_H 发表于 2015-8-6 20:35 | 显示全部楼层
谢谢您的回复  按照这个程序我判断应该是发送完毕后 led会亮灭,但是只能看到它一直亮,从程序一下载进去就亮,不知道怎么回事
dirtwillfly 发表于 2015-8-6 20:57 | 显示全部楼层
谢谢您的回复  按照这个程序我判断应该是发送完毕后 led会亮灭,但是只能看到它一直亮,从程序一下载进去 ...
你的Delay(200); 是延时多少?
 楼主| Sssss_H 发表于 2015-8-7 10:27 | 显示全部楼层
0.0几秒
