参考:数据通道;带**频信号
1817|1
 楼主| hlhfootbal 发表于 2008-4-3 17:20 | 显示全部楼层 |阅读模式
AN, RF, TE, CD, ip
An&nbsp;nRF24L01&nbsp;configured&nbsp;as&nbsp;primary&nbsp;RX&nbsp;(PRX)&nbsp;will&nbsp;be&nbsp;able&nbsp;to&nbsp;receive&nbsp;data&nbsp;trough&nbsp;6&nbsp;different&nbsp;data&nbsp;pipes.<br />请问data&nbsp;pipes是什么意思?<br />Carrier&nbsp;Detect&nbsp;(CD)&nbsp;is&nbsp;set&nbsp;high&nbsp;when&nbsp;an&nbsp;in-band&nbsp;RF&nbsp;signal&nbsp;is&nbsp;detected&nbsp;in&nbsp;RX&nbsp;mode,otherwise&nbsp;CD&nbsp;is&nbsp;low.<br />请问an&nbsp;in-band&nbsp;RF&nbsp;signal是什么意思?<br />谢谢!
iC921 发表于 2008-4-9 16:33 | 显示全部楼层
参考:数据通道;带**频信号
