第一次弄IMX6- 单 用MFG 烧录一直卡在这里下不去,开发板是OK的。这板是我们是根据Development board改的。UBOOT_SEL &BOOTMODE switch都改成一样了。EMCC为4.5 (镁光)申明:DDR3 DQ19 DQ21 板子已Swap.(HW CHECK LIST允许) LOG部份信息如下 望各路大神看下 给点意见方向。。。
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[0065DCB8] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is E:\working\MFG_TOOL\Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\u-boot-mx6solo-RIoTboard.bin
