很好奇,下文中的优化指令序列是什么?会导致Z/B版本不兼
2469|1
 楼主| pheavecn 发表于 2008-12-5 10:23 | 显示全部楼层 |阅读模式
2.6 Compatibility issue with latest compiler releases
Description
Compilers with improved optimizations for the STM32F10xxx have been recently released
on the market. Revisions Z and B of the medium-density STM32F10xxx devices
(STM32F10xx8/B) do not support some of the sequences associated with the high-level
optimizations done in these compilers. Revision Y is not affected by this limitation.
Errata sheet STM32F10xxx silicon limitations
7/14
Workaround
This behavior is fully deterministic, and should be detected during firmware development or
the validation phase. Consequently, systems already developed, validated and delivered to
the field with previous silicon revisions are not affected.
For code update of revision Z and B devices already in the field, do not use these new
compilers. To date, compilers known to generate these sequences are:
● IAR EWARM rev 5.20 and later
● GNU rev 4.2.3 and later
For new developments associated with these compilers, revision Y of the STM32F10xx8/B
must be used.
 楼主| pheavecn 发表于 2008-12-8 09:20 | 显示全部楼层
找到了,应该是这个问题。
ARM: CHECKING FOR CORTEX-M3 LDRD ERRATA 602117
LDRD r0,[R0]这样的指令碰到中断,会出错。
