- * FileName : adc.c
- * Copyright :
- * ModuleName :
- * CPU :
- * RTOS :
- * CreateData :
- * Author/Corporation :
- * Description : ad驱动
- *---------------------Revision History------------------------
- * No Version Date Revised By Item Description
- #include "adc.h"
- #include "stm32f0xx_adc.h"
- #include "stm32f0xx_gpio.h"
- #include "stm32f0xx_dma.h"
- #include "stm32f0xx_misc.h"
- #define ADC1_DR_Address 0x40012440 //外设地址
- __IO UINT16 ADC1ConvValue[3] = {0}; //采样数据保存数组
- __IO UINT16 atomizevalue[ADCCONV_NUM]; //雾化片电流保存数组
- __IO UINT16 batteryvalue[ADCCONV_NUM]; //电池电压保存数组
- __IO UINT16 usbchargevalue[ADCCONV_NUM]; //USB充电电压保存数组
- __IO UINT8 adccount = 0;
- __IO UINT8 idxbuffer = 0;
- * Function Name : adcinit
- * Param : void
- * Return Param : void
- * Description : adc初始化配置
- void adcinit(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- ADC_InitTypeDef ADC_InitStruct;
- DMA_InitTypeDef DMA_InitStruct;
- NVIC_InitTypeDef NVIC_InitStruct;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AN;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- //GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
- GPIO_Init(GPIOA,&GPIO_InitStruct);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
- GPIO_Init(GPIOB,&GPIO_InitStruct);
- ADC_StructInit(&ADC_InitStruct);
- ADC_InitStruct.ADC_Resolution = ADC_Resolution_12b;
- ADC_InitStruct.ADC_ContinuousConvMode = ENABLE;
- ADC_InitStruct.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
- ADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStruct.ADC_ScanDirection = ADC_ScanDirection_Upward;
- ADC_Init(ADC1,&ADC_InitStruct);
- ADC_ChannelConfig(ADC1,ADC_Channel_0,ADC_SampleTime_55_5Cycles);
- ADC_ChannelConfig(ADC1,ADC_Channel_1,ADC_SampleTime_55_5Cycles);
- ADC_ChannelConfig(ADC1,ADC_Channel_2,ADC_SampleTime_55_5Cycles);
- ADC_GetCalibrationFactor(ADC1);
- DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
- DMA_InitStruct.DMA_MemoryBaseAddr = (uint32_t)&ADC1ConvValue; //内存映射地址
- DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStruct.DMA_BufferSize = 3;
- DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStruct.DMA_Mode = DMA_Mode_Circular;
- DMA_InitStruct.DMA_Priority = DMA_Priority_High;
- DMA_InitStruct.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1,&DMA_InitStruct);
- NVIC_InitStruct.NVIC_IRQChannel = DMA1_Channel1_IRQn;
- NVIC_InitStruct.NVIC_IRQChannelPriority = 2;
- NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStruct);
- DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE); //开DMA中断
- DMA_Cmd(DMA1_Channel1,ENABLE);
- ADC_DMARequestModeConfig(ADC1,ADC_DMAMode_Circular);
- ADC_DMACmd(ADC1,ENABLE);
- ADC_Cmd(ADC1,ENABLE);
- * Function Name : getadcvalue
- * Param : const void * data, UINT8 length
- * Return Param : UINT16
- * Description : 获取adc转换结果
- UINT16 getadcvalue(void * data, UINT8 length)
- UINT16 adcresult = 0;
- if(length == 0)
- return adcresult;
- while(ADC_GetFlagStatus(ADC1,ADC_FLAG_ADRDY) == DISABLE);
- while((ADC1->CR & 0x04) != DISABLE);
- ADC_StartOfConversion(ADC1);
- //if(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOSEQ) == ENABLE)
- // ADC_ClearFlag(ADC1,ADC_FLAG_EOSEQ);
- adcresult = buffer_avg(data,length);
- return adcresult;
- * Function Name : buffer_avg
- * Param : void
- * Description : 获取平均值
- UINT16 buffer_avg(void * data, UINT8 length)
- UINT16 avgdata = 0;
- UINT16 sum = 0;
- UINT8 idx;
- if(length == 0)
- return avgdata;
- for(idx = 0;idx < length;idx++)
- sum += ((UINT16 *)data)[idx];
- avgdata = (UINT16)(sum / length);
- return avgdata;
- * Function Name : DMA1_Channel1_IRQHandler
- * Param : void
- * Description : DMA中断获取adc转换结果
- void DMA1_Channel1_IRQHandler(void)
- while(DMA_GetITStatus(DMA_IT_TC) == RESET);
- adccount++;
- if(0 == (adccount % 3))
- atomizevalue[idxbuffer] = ADC1ConvValue[0];
- batteryvalue[idxbuffer] = ADC1ConvValue[1];
- usbchargevalue[idxbuffer] = ADC1ConvValue[2];
- idxbuffer++;
- if((3 * ADCCONV_NUM) == adccount)
- adccount = 0;
- idxbuffer = 0;
- ADC_StopOfConversion(ADC1);
- DMA_ClearITPendingBit(DMA_IT_TC);
