[STM8] 修复STM8 ADC连续转换只进行一次的错误
1656|3
 楼主| mzhboy 发表于 2015-10-25 21:41 | 显示全部楼层 |阅读模式
原来在ADC1_IRQHandler()函数末尾使用 ADC1_ClearITPendingBit(ADC1_IT_EOCIE)来处理中断标志,结果发现ADC只进入一次中断。但是如果在主循环中读取ADC数据寄存器却能够读到。
后来发现坑爹的结构体
  1. typedef enum
  3.   ADC1_IT_AWDIE = (uint16_t)0x010, /**< Analog WDG interrupt enable */
  4.   ADC1_IT_EOCIE = (uint16_t)0x020, /**< EOC interrupt enable */
  5.   ADC1_IT_AWD   = (uint16_t)0x140, /**< Analog WDG status */
  6.   ADC1_IT_AWS0  = (uint16_t)0x110, /**< Analog channel 0 status */
  7.   ADC1_IT_AWS1  = (uint16_t)0x111, /**< Analog channel 1 status */
  8.   ADC1_IT_AWS2  = (uint16_t)0x112, /**< Analog channel 2 status */
  9.   ADC1_IT_AWS3  = (uint16_t)0x113, /**< Analog channel 3 status */
  10.   ADC1_IT_AWS4  = (uint16_t)0x114, /**< Analog channel 4 status */
  11.   ADC1_IT_AWS5  = (uint16_t)0x115, /**< Analog channel 5 status */
  12.   ADC1_IT_AWS6  = (uint16_t)0x116, /**< Analog channel 6 status */
  13.   ADC1_IT_AWS7  = (uint16_t)0x117, /**< Analog channel 7 status */
  14.   ADC1_IT_AWS8  = (uint16_t)0x118, /**< Analog channel 8 status */
  15.   ADC1_IT_AWS9  = (uint16_t)0x119, /**< Analog channel 9 status */
  16.   ADC1_IT_AWS12 = (uint16_t)0x11C, /**< Analog channel 12 status */
  17.                                    /* refer to product datasheet for channel 12 availability */
  18.   ADC1_IT_EOC   = (uint16_t)0x080  /**< EOC pending bit */
  19. } ADC1_IT_TypeDef;
定义的前两个都是关闭中断用的。前面的用法导致只能进入一次中断。
所以正确的清除中断标志是清EOC,两个函数ADC1_ClearITPendingBit(ADC1_IT_EOC)或者ADC1_ClearFlag(ADC1_FLAG_EOC)都是可以的
天灵灵地灵灵 发表于 2015-10-25 23:01 | 显示全部楼层
正确的清除中断标志是清EOC,两个函数ADC1_ClearITPendingBit(ADC1_IT_EOC)或者ADC1_ClearFlag(ADC1_FLAG_EOC)都是可以的。
很厉害啊,这都发现了
309030106 发表于 2015-10-28 19:56 | 显示全部楼层
楼主细心啊,学习了
冰河w 发表于 2015-10-28 20:56 | 显示全部楼层
区别就在ADC1_IT_EOCIE和ADC1_IT_EOC了
