Lease of 10.24.1.141 obtained, lease time 1209600
/etc/udhcpc.d/50default: Adding DNS 202.96.209.5
/etc/udhcpc.d/50default: Adding DNS 202.96.209.133
done.
Starting rpcbind daemon...done.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
这个之后的start 应该就是启动后运行的脚本了。这些都是写在哪里的?
rc.local里面没有。找了找也没找到
INIT: Entering runlevel: 5
Starting Xserver
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
Starting advanced power management daemon: No APM support in kernel
(failed.)
creating NFS state directory: done
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
...done.
Starting Telephony daemon
Starting Linux NFC daemon
Starting OProfileUI server
Running local boot scripts (/etc/rc.local).
Stopping Bootlog daemon: bootlogd.
Poky (Yocto Project Reference Distro) 1.5.1 imx6qdlsolo /dev/ttymxc0
imx6qdlsolo login: libphy: 2188000.ethernet:01 - Link is Up - 100/Full
