[疑难问答] 矩阵键盘0,1,3控制时钟的定位 加减
1216|2
 楼主| 袖口——光阴 发表于 2015-11-22 17:45 | 显示全部楼层 |阅读模式
#include<reg52.h>
unsigned char code a[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; c[]={0xfe,0xfd,0xf7,0xef,0xbf,0x7f} ;here[6];
void  xianshi();
void  singsong();
void keydown();
void timer1();
  sbit fmq=P1^5;
unsigned char keyvalue,i=0,keypress,miao=0;M=0;minute=0;hour=0;r=0;
  void delay(unsigned int i)
{          char j;
             for(i; i > 0; i--)
    for(j = 115; j> 0; j--);
void main()
  fmq=0;
  TMOD=0x01;
  TR0=1;
  ET0=1;
  EA=1;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
while(1)
  xianshi();
  singsong();
keydown();
switch(keyvalue)
case(0xee):
    miao=10;
    keyvalue=0xff;
  break;
case(0xed):
  miao++;
  keyvalue=0xff;
   break;
case(0xeb):
    miao--;
         break;
miao=0;
void timer() interrupt 1
   M++;
if(M==20)
   miao++;
  if(miao==60)
  miao=0;
  minute++;
if(minute==10)
  minute=0;
  hour++;
if(hour==12)
  hour=0;
M=0;
void keydown(void)
{unsigned char key;
P3=0xf0;
key=P3|0x0f;
  if(key!=0xff)
                delay(10);
                        P3=0xf0;
                        key=P3|0x0f;
                if(key!=0xff)
                {        P3=key;
                        keyvalue=P3;
                   keypress=1;
void xianshi(void)
{ int b;
for(b=0;b<6;b++)
   here[1]=miao/10;
   here[0]=miao%10;
   here[2]=minute%10;
   here[3]=minute/10;
   here[4]=hour%10;
   here[5]=hour/10;
   P2=0xff;
   P0=0xff;
   P2=c;
   P0=a[here];
   delay(1);
void singsong()
{  int i;
if(miao==35)
{         for(i=0;i<50;i++)
  {  fmq=1;
        delay(1);
        fmq=0;
        delay(1);
为啥  实现加1  减1  时控制不好
CallReceiver 发表于 2015-12-8 20:39 | 显示全部楼层
想要实现加1  减1 你是怎么设计 的呢??
会飞の鱼 发表于 2015-12-12 14:24 | 显示全部楼层
你这延时函数起什么作用啊
