[STM32F2] 官方flash模拟eeprom疑问
1164|0
 楼主| gzw19900817 发表于 2015-12-7 11:50 | 显示全部楼层 |阅读模式
在官方历程中,若旧页满,则复制旧页的有效数据到新页,而在这个复制有效数据的函数中,对新页的同个地址进行重复的写操作,这样应该有问题吧,原函数如下:
  * @brief  Transfers last updated variables data from the full Page to
  *   an empty one.
  * @param  VirtAddress: 16 bit virtual address of the variable
  * @param  Data: 16 bit data to be written as variable value
  * @retval Success or error status:
  *           - FLASH_COMPLETE: on success
  *           - PAGE_FULL: if valid page is full
  *           - NO_VALID_PAGE: if no valid page was found
  *           - Flash error code: on write Flash error
static uint16_t EE_PageTransfer(uint16_t VirtAddress, uint16_t Data)
  FLASH_Status FlashStatus = FLASH_COMPLETE;
  uint32_t NewPageAddress = EEPROM_START_ADDRESS;
  uint16_t OldPageId=0;
  uint16_t ValidPage = PAGE0, VarIdx = 0;
  uint16_t EepromStatus = 0, ReadStatus = 0;
  /* Get active Page for read operation */
  ValidPage = EE_FindValidPage(READ_FROM_VALID_PAGE);
  if (ValidPage == PAGE1)       /* Page1 valid */
    /* New page address where variable will be moved to */
    NewPageAddress = PAGE0_BASE_ADDRESS;
    /* Old page ID where variable will be taken from */
    OldPageId = PAGE1_ID;
  else if (ValidPage == PAGE0)  /* Page0 valid */
    NewPageAddress = PAGE1_BASE_ADDRESS;
    OldPageId = PAGE0_ID;
  else
    return NO_VALID_PAGE;       /* No valid Page */
  /* Set the new Page status to RECEIVE_DATA status */
  FlashStatus = FLASH_ProgramHalfWord(NewPageAddress, RECEIVE_DATA);  /* If program operation was failed, a Flash error code is returned */
  if (FlashStatus != FLASH_COMPLETE)
    return FlashStatus;
  /* Write the variable passed as parameter in the new active page */
  EepromStatus = EE_VerifyPageFullWriteVariable(VirtAddress, Data);
  if (EepromStatus != FLASH_COMPLETE)
    return EepromStatus;
  /* Transfer process: transfer variables from old to the new active page */
  for (VarIdx = 0; VarIdx < NB_OF_VAR; VarIdx++)
    if (VirtAddVarTab[VarIdx] != VirtAddress)  /* Check each variable except the one passed as parameter */
      /* Read the other last variable updates */
      ReadStatus = EE_ReadVariable(VirtAddVarTab[VarIdx], &DataVar);
      /* In case variable corresponding to the virtual address was found */
      if (ReadStatus != 0x1)
        /* Transfer the variable to the new active page */
        EepromStatus = EE_VerifyPageFullWriteVariable(VirtAddVarTab[VarIdx], DataVar);
  /* Erase the old Page: Set old Page status to ERASED status */
  FlashStatus = FLASH_EraseSector(OldPageId, VOLTAGE_RANGE);
  /* If erase operation was failed, a Flash error code is returned */
    return FlashStatus;
  /* Set new Page status to VALID_PAGE status */
  FlashStatus = FLASH_ProgramHalfWord(NewPageAddress, VALID_PAGE);  /* If program operation was failed, a Flash error code is returned */
    return FlashStatus;
  /* Return last operation flash status */
  return FlashStatus;
