  * [url=home.php?mod=space&uid=288409]@file[/url]    ADC/TIMTrigger_AutoInjection/main.c
  * [url=home.php?mod=space&uid=187600]@author[/url]  MCD Application Team
  * [url=home.php?mod=space&uid=895143]@version[/url] V3.5.0
  * [url=home.php?mod=space&uid=212281]@date[/url]    08-April-2011
  * [url=home.php?mod=space&uid=247401]@brief[/url]   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup ADC_TIMTrigger_AutoInjection
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ADC1_DR_Address    ((uint32_t)0x4001244C)
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ADC_InitTypeDef           ADC_InitStructure;
DMA_InitTypeDef           DMA_InitStructure;
TIM_TimeBaseInitTypeDef   TIM_TimeBaseStructure;
TIM_OCInitTypeDef         TIM_OCInitStructure;
__IO uint16_t ADC_RegularConvertedValueTab[32], ADC_InjectedConvertedValueTab[32];
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
/* Private functions ---------------------------------------------------------*/
  * @brief   Main program
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
//  NVIC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* TIM1 configuration ------------------------------------------------------*/
  /* Time Base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 1000;
  TIM_TimeBaseStructure.TIM_Prescaler = 71;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* TIM1 channel1 configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 500;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  /* DMA1 Channel1 Configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_RegularConvertedValueTab;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 16;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA1 channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_71Cycles5);
  /* Set injected sequencer length */
  ADC_InjectedSequencerLengthConfig(ADC1, 1);
////  /* ADC1 injected channel Configuration */
////  ADC_InjectedChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_71Cycles5);
////  /* ADC1 injected external trigger configuration */
////  ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);
  /* Enable automatic injected conversion start after regular one */
  ADC_AutoInjectedConvCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 external trigger */
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);
////  /* Enable JEOC interrupt */
////  ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* TIM1 main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  while (1)
                TIM_Cmd(TIM1, ENABLE);
                /* Test on channel1 transfer complete flag */
                while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
                /* Clear channel1 transfer complete flag */
                DMA_ClearFlag(DMA1_FLAG_TC1);
                /* TIM1 counter disable */
                TIM_Cmd(TIM1, DISABLE);
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
  /* Enable peripheral clocks ------------------------------------------------*/
  /* Enable DMA1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  /* Enable GPIOA, GPIOC, ADC1 and TIM1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC |
                         RCC_APB2Periph_ADC1 | RCC_APB2Periph_TIM1, ENABLE);
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval None
  /* Configure TIM1_CH1 (PA8) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure PC.06 as output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* Configure PC.01 and PC.04 (ADC Channel11 and Channel14) as analog input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
