按键不起作用
1687|0
 楼主| s65788349 发表于 2008-5-17 16:58 | 显示全部楼层 |阅读模式
--&nbsp;mode?a¨|¨¨??¨oy?á??¨??a??¨oy??ê¨o??1¨o?¨|¨¨¨o?à??ê¨o?.|ì?à?a¨|¨¨¨o?à??ê¨o?¨o?à,inc?a????¨o?à????D?o?.p?a¨oy??1¨1????D?o?,N?a????¨oy??1¨1D?o?.<br />library&nbsp;IEEE;<br />use&nbsp;IEEE.STD_LOGIC_1164.ALL;<br />use&nbsp;IEEE.STD_LOGIC_ARITH.ALL;<br />use&nbsp;IEEE.STD_LOGIC_UNSIGNED.ALL;<br /><br />entity&nbsp;clock&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;Port&nbsp;(&nbsp;N&nbsp;:&nbsp;out&nbsp;std_logic_vector(7&nbsp;downto&nbsp;0);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;P&nbsp;:&nbsp;out&nbsp;std_logic_vector(3&nbsp;downto&nbsp;0);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;clk&nbsp;:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;reset,mode,inc:&nbsp;in&nbsp;std_logic);<br />end&nbsp;clock;<br /><br />architecture&nbsp;Behavioral&nbsp;of&nbsp;clock&nbsp;is<br />SIGNAL&nbsp;divcounter,divcounter1:&nbsp;std_logic_vector(27&nbsp;downto&nbsp;0);<br />SIGNAL&nbsp;divclk,clk2:std_logic;<br />SIGNAL&nbsp;blink:&nbsp;std_logic_vector(3&nbsp;downto&nbsp;0);<br />SIGNAL&nbsp;scan:std_logic_vector(8&nbsp;downto&nbsp;0);<br />SIGNAL&nbsp;scan_clk:std_logic_vector(1&nbsp;downto&nbsp;0);<br />signal&nbsp;state:std_logic_vector(2&nbsp;downto&nbsp;0);&nbsp;--clock&nbsp;state.<br />SIGNAL&nbsp;sec_counter1,sec_counter2,min_counter1,min_counter2:std_logic_vector(3&nbsp;downto&nbsp;0);<br />--SIGNAL&nbsp;sec_counter1,sec_counter2,min_counter1,min_counter2:std_logic_vector(3&nbsp;downto&nbsp;0);<br />signal&nbsp;data:std_logic_vector(3&nbsp;downto&nbsp;0);<br /><br />begin<br />process(clk)<br />begin<br />&nbsp;&nbsp;&nbsp;if&nbsp;clk='1'&nbsp;and&nbsp;clk'event&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(divcounter&gt=X&quot;1312D00&quot;)&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;divcounter&lt=X&quot;0000000&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;divclk&lt=not&nbsp;divclk;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;divcounter&lt=divcounter+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;process;<br />--2Hz<br />process(clk)<br />begin<br />&nbsp;&nbsp;&nbsp;if&nbsp;clk='1'&nbsp;and&nbsp;clk'event&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(divcounter1&gt=X&quot;989680&quot;)&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;divcounter1&lt=X&quot;0000000&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;clk2&lt=not&nbsp;clk2;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;divcounter1&lt=divcounter1+'1';<br />&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;process;<br /><br /><br />--&nbsp;mode&nbsp;change<br />process(reset,divclk)<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;if(reset='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;state&lt=&quot;000&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;elsif(divclk'event&nbsp;and&nbsp;divclk='1')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(mode='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(state&gt=&quot;100&quot;)&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;state&lt=&quot;000&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;state&lt=state+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />end&nbsp;process;<br /><br />process(state)<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;state&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;000&quot;=&gt&nbsp;blink&lt=(others=&gt'1');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;001&quot;=&gt&nbsp;blink&lt=(0=&gtclk2,others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;010&quot;=&gt&nbsp;blink&lt=(1=&gtclk2,others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;011&quot;=&gt&nbsp;blink&lt=(2=&gtclk2,others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;100&quot;=&gt&nbsp;blink&lt=(3=&gtclk2,others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;others=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;case;<br />end&nbsp;process;<br />--count<br />process(divclk,reset,state)<br />--variable&nbsp;sec_counter1,sec_counter2,min_counter1,min_counter2:std_logic_vector(3&nbsp;downto&nbsp;0);<br />&nbsp;&nbsp;&nbsp;begin<br />&nbsp;&nbsp;&nbsp;&nbsp;if(reset='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter1&lt=(others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter2&lt=(others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter1&lt=(others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter2&lt=(others=&gt'0');<br />&nbsp;&nbsp;&nbsp;&nbsp;elsif&nbsp;(divclk'event&nbsp;and&nbsp;divclk='1')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;state&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;000&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(sec_counter1&gt=X&quot;9&quot;)&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter1&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(sec_counter2&gt=X&quot;5&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter2&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(min_counter1&gt=X&quot;9&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter1&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(min_counter2&gt=X&quot;5&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter2&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter2&lt=min_counter2+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter1&lt=min_counter1+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter2&lt=sec_counter2+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter1&lt=sec_counter1+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;001&quot;=&gt&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(inc='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(min_counter2&gt=X&quot;5&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter2&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;min_counter2&lt=min_counter2+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;010&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(inc='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(min_counter1&gt=X&quot;9&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;min_counter1&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;min_counter1&lt=min_counter1+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;011&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(inc='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(sec_counter2&gt=X&quot;5&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter2&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;sec_counter2&lt=sec_counter2+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;100&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(inc='0')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(sec_counter1&gt=X&quot;9&quot;)then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sec_counter1&lt=X&quot;0&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else&nbsp;sec_counter1&lt=sec_counter1+'1';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;others=&gt&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;case;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;process;<br /><br />--scan&nbsp;count<br />process(clk)<br />&nbsp;&nbsp;&nbsp;begin<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;(clk'event&nbsp;and&nbsp;clk='1')&nbsp;then<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;scan&lt=scan+1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;end&nbsp;process;<br />&nbsp;&nbsp;&nbsp;scan_clk&lt=scan(8&nbsp;downto&nbsp;7);<br /><br />process(scan_clk)<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;scan_clk&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;00&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;data&lt=sec_counter1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;P&lt=&quot;1000&quot;&nbsp;and&nbsp;blink;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;01&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;data&lt=sec_counter2;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;P&lt=&quot;0100&quot;&nbsp;and&nbsp;blink;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;10&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;data&lt=min_counter1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;P&lt=&quot;0010&quot;&nbsp;and&nbsp;blink;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;&quot;11&quot;=&gt<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;data&lt=min_counter2;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;P&lt=&quot;0001&quot;&nbsp;and&nbsp;blink;<br />&nbsp;&nbsp;&nbsp;when&nbsp;others=&gtdata&lt=&quot;1111&quot;;P&lt=&quot;0000&quot;;<br />&nbsp;&nbsp;end&nbsp;case;<br />end&nbsp;process;<br /><br />process(data)<br />begin<br />&nbsp;&nbsp;case&nbsp;data&nbsp;is<br />&nbsp;&nbsp;when&nbsp;&quot;0000&quot;&nbsp;=&gtN&lt=&quot;10001000&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0001&quot;&nbsp;=&gtN&lt=&quot;11011011&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0010&quot;&nbsp;=&gtN&lt=&quot;10100010&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0011&quot;&nbsp;=&gtN&lt=&quot;10010010&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0100&quot;&nbsp;=&gtN&lt=&quot;11010001&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0101&quot;&nbsp;=&gtN&lt=&quot;10010100&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0110&quot;&nbsp;=&gtN&lt=&quot;10000100&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;0111&quot;&nbsp;=&gtN&lt=&quot;11011010&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;1000&quot;&nbsp;=&gtN&lt=&quot;10000000&quot;;<br />&nbsp;&nbsp;when&nbsp;&quot;1001&quot;&nbsp;=&gtN&lt=&quot;10010000&quot;;<br />&nbsp;&nbsp;when&nbsp;&nbsp;others&nbsp;=&gtN&lt=&quot;11111111&quot;;<br />&nbsp;&nbsp;end&nbsp;case;<br />end&nbsp;process;<br />&nbsp;<br />end&nbsp;Behavioral;<br />以上为源程序,当inc=‘0’时,应该加1的,但并没有加1,不知何原因?
