请教:关于2410带电复位后CP15协处理器状态
2892|1
 楼主| xzm0662 发表于 2007-11-21 15:27 | 显示全部楼层 |阅读模式
如果在运行状态,用reset信号复位2410,那么CP15会改变状态吗?如果已启用MMU,大端模式,复位后CP15能回到小端,关闭MMU吗?<br />外设寄存器很多都有确定的复位值,但是cp15是协处理器,它有复位吗?<br />2410手册这么写的复位动作,不过没有提到协处理器阿?<br />When&nbsp;nRESET&nbsp;goes&nbsp;HIGH&nbsp;again,&nbsp;ARM920T:<br />1.&nbsp;Overwrites&nbsp;R14_svc&nbsp;and&nbsp;SPSR_svc&nbsp;by&nbsp;copying&nbsp;the&nbsp;current&nbsp;values&nbsp;of&nbsp;the&nbsp;PC&nbsp;and&nbsp;CPSR&nbsp;into&nbsp;them.&nbsp;The&nbsp;value&nbsp;of<br />the&nbsp;saved&nbsp;PC&nbsp;and&nbsp;SPSR&nbsp;is&nbsp;not&nbsp;defined.<br />2.&nbsp;Forces&nbsp;M[4:0]&nbsp;to&nbsp;10011&nbsp;(Supervisor&nbsp;mode),&nbsp;sets&nbsp;the&nbsp;I&nbsp;and&nbsp;F&nbsp;bits&nbsp;in&nbsp;the&nbsp;CPSR,&nbsp;and&nbsp;clears&nbsp;the&nbsp;CPSR's&nbsp;T&nbsp;bit.<br />3.&nbsp;Forces&nbsp;the&nbsp;PC&nbsp;to&nbsp;fetch&nbsp;the&nbsp;next&nbsp;instruction&nbsp;from&nbsp;address&nbsp;0x00.<br />4.&nbsp;Execution&nbsp;resumes&nbsp;in&nbsp;ARM&nbsp;state.<br />
taiziniang 发表于 2008-6-12 13:55 | 显示全部楼层
期待中
o&nbsp;也想知道
