请教:关于2410带电复位后CP15协处理器状态
2815|1
xzm0662|  楼主 | 2007-11-21 15:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如果在运行状态,用reset信号复位2410,那么CP15会改变状态吗?如果已启用MMU,大端模式,复位后CP15能回到小端,关闭MMU吗?
外设寄存器很多都有确定的复位值,但是cp15是协处理器,它有复位吗?
2410手册这么写的复位动作,不过没有提到协处理器阿?
When nRESET goes HIGH again, ARM920T:
1. Overwrites R14_svc and SPSR_svc by copying the current values of the PC and CPSR into them. The value of
the saved PC and SPSR is not defined.
2. Forces M[4:0] to 10011 (Supervisor mode), sets the I and F bits in the CPSR, and clears the CPSR's T bit.
3. Forces the PC to fetch the next instruction from address 0x00.
4. Execution resumes in ARM state.
taiziniang| | 2008-6-12 13:55 | 只看该作者
期待中
o 也想知道
