请问,我用CCS3.1 F2812的simulator 时,错现如下问题:<br /><br /> DevEmuRegs.M0RAMDFT = 0x0300;<br /> DevEmuRegs.M1RAMDFT = 0x0300;<br /> DevEmuRegs.L0RAMDFT = 0x0300;<br /> DevEmuRegs.L1RAMDFT = 0x0300;<br /> DevEmuRegs.H0RAMDFT = 0x0300;<br /> 当运行到上面几句时,提示如下错问:<br />Can't Run Target CPU: Can't write to data memory 0x950, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x951, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x952, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x953, check memory config [-2184] <br />Can't Run Target CPU: Can't write to data memory 0x954, check memory config [-2184]<br /><br />cmd文件中<br />MEMORY<br />{<br />PAGE 1 : <br /> /* Peripheral Frame 0: */<br /> DEV_EMU : origin = 0x000880, length = 0x000180<br />}<br />SECTIONS<br />{ <br /> DevEmuRegsFile : > DEV_EMU, PAGE = 1<br />}<br /><br /><br />请问这是什么原因啊<br /> |
