[ZLG-ARM] fedora10 PPPOE拨号(家庭、校园网、单位)上网
2980|5
 楼主| lpczcy 发表于 2009-6-4 13:44 | 显示全部楼层 |阅读模式
首先确认你的网卡正常工作,让他处于自动获取IP状态,启动linux终端(root权限),因为fedora10下已经自带有pppoe的安装文件,可以直接输入如下命令,要想理解各个步骤是什么意思,那就看英语咯,我这里就不多解析了。<br /><br />[root@localhost&nbsp;~]#&nbsp;pppoe-setup&nbsp;&nbsp;---------------这里开始安装PPPOE<br /><br />Welcome&nbsp;to&nbsp;the&nbsp;PPPoE&nbsp;client&nbsp;setup.&nbsp;&nbsp;First,&nbsp;I&nbsp;will&nbsp;run&nbsp;some&nbsp;checks&nbsp;on<br />your&nbsp;system&nbsp;to&nbsp;make&nbsp;sure&nbsp;the&nbsp;PPPoE&nbsp;client&nbsp;is&nbsp;installed&nbsp;properly...<br /><br /><br />LOGIN&nbsp;NAME<br /><br />Enter&nbsp;your&nbsp;Login&nbsp;Name&nbsp;(default&nbsp;root):&nbsp;xy170638010214&nbsp;&nbsp;---------------这里键入上网拨号的帐号<br /><br />INTERFACE<br /><br />Enter&nbsp;the&nbsp;Ethernet&nbsp;interface&nbsp;connected&nbsp;to&nbsp;the&nbsp;PPPoE&nbsp;modem<br />For&nbsp;Solaris,&nbsp;this&nbsp;is&nbsp;likely&nbsp;to&nbsp;be&nbsp;something&nbsp;like&nbsp;/dev/hme0.<br />For&nbsp;Linux,&nbsp;it&nbsp;will&nbsp;be&nbsp;ethX,&nbsp;where&nbsp;'X'&nbsp;is&nbsp;a&nbsp;number.<br />(default&nbsp;eth0):&nbsp;---------------这里按回车键<br /><br />Do&nbsp;you&nbsp;want&nbsp;the&nbsp;link&nbsp;to&nbsp;come&nbsp;up&nbsp;on&nbsp;demand,&nbsp;or&nbsp;stay&nbsp;up&nbsp;continuously?<br />If&nbsp;you&nbsp;want&nbsp;it&nbsp;to&nbsp;come&nbsp;up&nbsp;on&nbsp;demand,&nbsp;enter&nbsp;the&nbsp;idle&nbsp;time&nbsp;in&nbsp;seconds<br />after&nbsp;which&nbsp;the&nbsp;link&nbsp;should&nbsp;be&nbsp;dropped.&nbsp;&nbsp;If&nbsp;you&nbsp;want&nbsp;the&nbsp;link&nbsp;to<br />stay&nbsp;up&nbsp;permanently,&nbsp;enter&nbsp;'no'&nbsp;(two&nbsp;letters,&nbsp;lower-case.)<br />NOTE:&nbsp;Demand-activated&nbsp;links&nbsp;do&nbsp;not&nbsp;interact&nbsp;well&nbsp;with&nbsp;dynamic&nbsp;IP<br />addresses.&nbsp;&nbsp;You&nbsp;may&nbsp;have&nbsp;some&nbsp;problems&nbsp;with&nbsp;demand-activated&nbsp;links.<br />Enter&nbsp;the&nbsp;demand&nbsp;value&nbsp;(default&nbsp;no):&nbsp;---------------这里按回车键<br /><br />DNS<br /><br />Please&nbsp;enter&nbsp;the&nbsp;IP&nbsp;address&nbsp;of&nbsp;your&nbsp;ISP's&nbsp;primary&nbsp;DNS&nbsp;server.<br />If&nbsp;your&nbsp;ISP&nbsp;claims&nbsp;that&nbsp;'the&nbsp;server&nbsp;will&nbsp;provide&nbsp;dynamic&nbsp;DNS&nbsp;addresses',<br />enter&nbsp;'server'&nbsp;(all&nbsp;lower-case)&nbsp;here.<br />If&nbsp;you&nbsp;just&nbsp;press&nbsp;enter,&nbsp;I&nbsp;will&nbsp;assume&nbsp;you&nbsp;know&nbsp;what&nbsp;you&nbsp;are<br />doing&nbsp;and&nbsp;not&nbsp;modify&nbsp;your&nbsp;DNS&nbsp;setup.<br />Enter&nbsp;the&nbsp;DNS&nbsp;information&nbsp;here:&nbsp;---------------这里键入&nbsp;&nbsp;&nbsp;server&nbsp;&nbsp;也就是自动获得DNS<br /><br />PASSWORD<br /><br />Please&nbsp;enter&nbsp;your&nbsp;Password:&nbsp;&nbsp;---------------这里键入上网拨号密码<br />Please&nbsp;re-enter&nbsp;your&nbsp;Password:&nbsp;---------------这里键入上网拨号密码<br /><br />USERCTRL<br /><br />Please&nbsp;enter&nbsp;'yes'&nbsp;(three&nbsp;letters,&nbsp;lower-case.)&nbsp;if&nbsp;you&nbsp;want&nbsp;to&nbsp;allow<br />normal&nbsp;user&nbsp;to&nbsp;start&nbsp;or&nbsp;stop&nbsp;DSL&nbsp;connection&nbsp;(default&nbsp;yes):&nbsp;&nbsp;&nbsp;---------------这里键入&nbsp;yes<br /><br />FIREWALLING<br /><br />Please&nbsp;choose&nbsp;the&nbsp;firewall&nbsp;rules&nbsp;to&nbsp;use.&nbsp;&nbsp;Note&nbsp;that&nbsp;these&nbsp;rules&nbsp;are<br />very&nbsp;basic.&nbsp;&nbsp;You&nbsp;are&nbsp;strongly&nbsp;encouraged&nbsp;to&nbsp;use&nbsp;a&nbsp;more&nbsp;sophisticated<br />firewall&nbsp;setup;&nbsp;however,&nbsp;these&nbsp;will&nbsp;provide&nbsp;basic&nbsp;security.&nbsp;&nbsp;If&nbsp;you<br />are&nbsp;running&nbsp;any&nbsp;servers&nbsp;on&nbsp;your&nbsp;machine,&nbsp;you&nbsp;must&nbsp;choose&nbsp;'NONE'&nbsp;and<br />set&nbsp;up&nbsp;firewalling&nbsp;yourself.&nbsp;&nbsp;Otherwise,&nbsp;the&nbsp;firewall&nbsp;rules&nbsp;will&nbsp;deny<br />access&nbsp;to&nbsp;all&nbsp;standard&nbsp;servers&nbsp;like&nbsp;Web,&nbsp;e-mail,&nbsp;ftp,&nbsp;etc.&nbsp;&nbsp;If&nbsp;you<br />are&nbsp;using&nbsp;SSH,&nbsp;the&nbsp;rules&nbsp;will&nbsp;block&nbsp;outgoing&nbsp;SSH&nbsp;connections&nbsp;which<br />allocate&nbsp;a&nbsp;privileged&nbsp;source&nbsp;port.<br /><br />The&nbsp;firewall&nbsp;choices&nbsp;are:<br />0&nbsp;-&nbsp;NONE:&nbsp;This&nbsp;script&nbsp;will&nbsp;not&nbsp;set&nbsp;any&nbsp;firewall&nbsp;rules.&nbsp;&nbsp;You&nbsp;are&nbsp;responsible<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;ensuring&nbsp;the&nbsp;security&nbsp;of&nbsp;your&nbsp;machine.&nbsp;&nbsp;You&nbsp;are&nbsp;STRONGLY<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;recommended&nbsp;to&nbsp;use&nbsp;some&nbsp;kind&nbsp;of&nbsp;firewall&nbsp;rules.<br />1&nbsp;-&nbsp;STANDALONE:&nbsp;Appropriate&nbsp;for&nbsp;a&nbsp;basic&nbsp;stand-alone&nbsp;web-surfing&nbsp;workstation<br />2&nbsp;-&nbsp;MASQUERADE:&nbsp;Appropriate&nbsp;for&nbsp;a&nbsp;machine&nbsp;acting&nbsp;as&nbsp;an&nbsp;Internet&nbsp;gateway<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;a&nbsp;LAN<br />Choose&nbsp;a&nbsp;type&nbsp;of&nbsp;firewall&nbsp;(0-2):&nbsp;0&nbsp;&nbsp;---------------这里键入&nbsp;0<br /><br />Start&nbsp;this&nbsp;connection&nbsp;at&nbsp;boot&nbsp;time<br /><br />Do&nbsp;you&nbsp;want&nbsp;to&nbsp;start&nbsp;this&nbsp;connection&nbsp;at&nbsp;boot&nbsp;time?<br />Please&nbsp;enter&nbsp;no&nbsp;or&nbsp;yes&nbsp;(default&nbsp;no):y&nbsp;&nbsp;---------------这里键入&nbsp;y&nbsp;&nbsp;<br /><br />**&nbsp;Summary&nbsp;of&nbsp;what&nbsp;you&nbsp;entered&nbsp;**<br /><br />Ethernet&nbsp;Interface:&nbsp;eth0<br />User&nbsp;name:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;xy170638010214<br />Activate-on-demand:&nbsp;No<br />DNS&nbsp;addresses:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Supplied&nbsp;by&nbsp;ISP's&nbsp;server<br />Firewalling:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;NONE<br />User&nbsp;Control:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;yes<br />Accept&nbsp;these&nbsp;settings&nbsp;and&nbsp;adjust&nbsp;configuration&nbsp;files&nbsp;(y/n)?&nbsp;y&nbsp;&nbsp;---------------这里键入&nbsp;y<br />Adjusting&nbsp;/etc/sysconfig/network-scripts/ifcfg-ppp0<br />Adjusting&nbsp;/etc/ppp/chap-secrets&nbsp;and&nbsp;/etc/ppp/pap-secrets<br />&nbsp;&nbsp;(But&nbsp;first&nbsp;backing&nbsp;it&nbsp;up&nbsp;to&nbsp;/etc/ppp/chap-secrets.bak)<br />&nbsp;&nbsp;(But&nbsp;first&nbsp;backing&nbsp;it&nbsp;up&nbsp;to&nbsp;/etc/ppp/pap-secrets.bak)<br /><br /><br /><br />Congratulations,&nbsp;it&nbsp;should&nbsp;be&nbsp;all&nbsp;set&nbsp;up!<br /><br />Type&nbsp;'/sbin/ifup&nbsp;ppp0'&nbsp;to&nbsp;bring&nbsp;up&nbsp;your&nbsp;xDSL&nbsp;link&nbsp;and&nbsp;'/sbin/ifdown&nbsp;ppp0'<br />to&nbsp;bring&nbsp;it&nbsp;down.<br />Type&nbsp;'/sbin/pppoe-status&nbsp;/etc/sysconfig/network-scripts/ifcfg-ppp0'<br />to&nbsp;see&nbsp;the&nbsp;link&nbsp;status.<br /><br />[root@localhost&nbsp;~]#&nbsp;pppoe-start&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;---------------激活PPPOE设备,成功后会自动返回<br />[root@localhost&nbsp;~]#&nbsp;pppoe-status&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;---------------查看PPPOE状态<br />pppoe-status:&nbsp;Link&nbsp;is&nbsp;up&nbsp;and&nbsp;running&nbsp;on&nbsp;interface&nbsp;ppp0<br />6:&nbsp;ppp0:&nbsp;&lt&nbsp;POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP&gt&nbsp;mtu&nbsp;1492&nbsp;qdisc&nbsp;pfifo_fast&nbsp;state&nbsp;UNKNOWN&nbsp;qlen&nbsp;3<br />&nbsp;&nbsp;&nbsp;&nbsp;link/ppp<br />&nbsp;&nbsp;&nbsp;&nbsp;inet&nbsp;113.14.36.24&nbsp;peer&nbsp;113.14.32.1/32&nbsp;scope&nbsp;global&nbsp;ppp0&nbsp;&nbsp;---------------这里有IP分配给你了,可以知道你已经成功登录这个帐号了。我们ping下百度IP看看&nbsp;&nbsp;通了,所以可以上网咯。<br />[root@localhost&nbsp;~]#&nbsp;ping&nbsp;121.14.88.14<br />PING&nbsp;121.14.88.14&nbsp;(121.14.88.14)&nbsp;56(84)&nbsp;bytes&nbsp;of&nbsp;data.<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=1&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=2&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=3&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=4&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=5&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />^C64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=6&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=7&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=8&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=9&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=10&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=11&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=12&nbsp;ttl=54&nbsp;time=17.7&nbsp;ms<br />^C64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=13&nbsp;ttl=54&nbsp;time=18.1&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=14&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=15&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />^C^X64&nbsp;bytes&nbsp;from&nbsp;121.14.88.14:&nbsp;icmp_seq=16&nbsp;ttl=54&nbsp;time=17.6&nbsp;ms<br />^X^C<br />---&nbsp;121.14.88.14&nbsp;ping&nbsp;statistics&nbsp;---<br />16&nbsp;packets&nbsp;transmitted,&nbsp;16&nbsp;received,&nbsp;0%&nbsp;packet&nbsp;loss,&nbsp;time&nbsp;15895ms<br />rtt&nbsp;min/avg/max/mdev&nbsp;=&nbsp;17.675/17.744/18.170/0.175&nbsp;ms<br />[root@localhost&nbsp;~]#&nbsp;pppoe-status<br />pppoe-status:&nbsp;Link&nbsp;is&nbsp;up&nbsp;and&nbsp;running&nbsp;on&nbsp;interface&nbsp;ppp0<br />6:&nbsp;ppp0:&nbsp;&lt&nbsp;POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP&gt&nbsp;mtu&nbsp;1492&nbsp;qdisc&nbsp;pfifo_fast&nbsp;state&nbsp;UNKNOWN&nbsp;qlen&nbsp;3<br />&nbsp;&nbsp;&nbsp;&nbsp;link/ppp<br />&nbsp;&nbsp;&nbsp;&nbsp;inet&nbsp;113.14.36.24&nbsp;peer&nbsp;113.14.32.1/32&nbsp;scope&nbsp;global&nbsp;ppp0<br />[root@localhost&nbsp;~]#<br /><br />以下是对PPPOE的基本操作<br /><br />使用:<br />拨号上网&nbsp;pppoe-start<br />段开上网&nbsp;pppoe-stop<br />查看状态&nbsp;pppoe-status&nbsp;<br /><br /><br />&nbsp;<br />&nbsp;<br /><br />&nbsp;<br /> &nbsp;&nbsp;<br />
miclinux 发表于 2009-6-4 14:05 | 显示全部楼层
好帖
billen 发表于 2009-6-4 15:54 | 显示全部楼层
用Linux的人不多啊
ArvinLiang 发表于 2011-11-6 20:58 | 显示全部楼层
很不错,很详细,很强大
bairan168 发表于 2011-11-9 20:53 | 显示全部楼层
真够给力的,09的贴子了,也得顶。
shuaibaobao 发表于 2011-11-23 15:58 | 显示全部楼层
我用了很长时间这个,但是还是感觉不是那么太顺手。
