[STM32L0] 用的是定时器3 怎么 需要 操作定时器 2 呢?
1350|7
 楼主| zhuhuis 发表于 2016-1-31 19:05 | 显示全部楼层 |阅读模式
下面是初始化TIM3为正交编码器模式
void ENC_Init(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_ICInitTypeDef TIM_ICInitStructure;
/* Encoder unit connected to TIM3, 4X mode */
NVIC_InitTypeDef NVIC_InitStructure;
/* TIM3 clock source enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
/* Enable GPIOA, clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_StructInit(&GPIO_InitStructure);
/* Configure PA.06,07 as encoder input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Enable the TIM3 Update Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =
TIMx_PRE_EMPTION_PRIORITY;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = TIMx_SUB_PRIORITY;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Timer configuration in Encoder mode */
TIM_DeInit(ENCODER_TIMER);
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Prescaler = 0x0; // No prescaling
TIM_TimeBaseStructure.TIM_Period = ENCODER_TIM_PERIOD;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(ENCODER_TIMER, &TIM_TimeBaseStructure);
TIM_EncoderInterfaceConfig(ENCODER_TIMER, TIM_EncoderMode_TI12,
                             TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
TIM_ICStructInit(&TIM_ICInitStructure);
TIM_ICInitStructure.TIM_ICFilter = ICx_FILTER;
TIM_ICInit(ENCODER_TIMER, &TIM_ICInitStructure);
// Clear all pending interrupts
TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update);
TIM_ITConfig(ENCODER_TIMER, TIM_IT_Update, ENABLE);
//Reset counter
TIM2->CNT = COUNTER_RESET;
// ENC_Clear_Speed_Buffer();
TIM_Cmd(ENCODER_TIMER, ENABLE);
tian111 发表于 2016-1-31 19:05 | 显示全部楼层
上面的 是官方 提供的 例子
宋倩2010 发表于 2016-1-31 19:06 | 显示全部楼层
我也是看到这个。后面一直想不通。最后安慰自己,是人都有犯错的时候。加上就算这里错了对当前整个程序无影响。
 楼主| zhuhuis 发表于 2016-1-31 19:06 | 显示全部楼层
LS  那去掉 有无 影响啊   ?你调试成功了每有呀?
chenho 发表于 2016-1-31 19:06 | 显示全部楼层
编码器调不通
 楼主| zhuhuis 发表于 2016-1-31 19:07 | 显示全部楼层
那搞毛啊
风呼呼 发表于 2017-7-12 15:52 | 显示全部楼层
楼主,为什么仿照上面的例程编写程序,测试发现有时候计数器计数的方向与STM官方给的编码器模块的资料上显示的是相反的呢?
