供应HP MSL6030 MSL6060
1626|0
 楼主| xxjpj2009 发表于 2009-9-9 10:38 | 显示全部楼层 |阅读模式
公司提供小型机、服务器、工作站、存储设备、外设、CPU 内存 硬盘 电源 存储设备 控制卡 升级选件、维修配件(HP、IBM、EMC)等
联系人:李先生    联系电话:010-88147562
hot-plug canister (Ultrium 460)
231683-001   Terminator, VHDCI, LVD, SCSI  Sys_flag:== MSL6000
Number      Description
231676-001   Barcode Reader
Q2002A       Barcode Labels, Ultrium Generation 2, 100 pack (100 data cartridge labels, 10 cleaning cartridge labels per pack)
246729-001   Belt,  Pass Thru
305550-001   Bracket, rack
970946-310   Brass Screws
231677-001   MSL6030 - Cable, Flex, Kit
263641-001   MSL6060 - Cable, Flex, Kit
231687-001   Cable, SCSI High Density .25m (Not recommended for MSL6000, single drive per Bus)
231687-002   Cable, SCSI  High Density .5m
300576-001   Cable, Serial, RJ11/DB9F
305421-001   Cartridge, LTO 1, 100/200 GB, Media
C7972A       Cartridge, LTO 2, 200/400 GB, Media (recommended)
305422-001   Cartridge, LTO Cleaning
231666-001   Display, LCD Touch
305551-001   Fan, Backplane, 18 CFM
231670-001   Fan, Backplane
263643-001   Fan, Card Cage
606989-003   Front Panel, Includes Display,  Graphite 5U
606989-004   Front Panel, Includes Display, Graphite 10U
231682-001   Guide, Drive
Q2002A       HP Ultrium 2 bar code label pack (Option kit includes 100 data and 10 cleaning labels.)
C7972AL      HP Ultrium 400GB Pre-Labeled Data Cartridge
303075-001   Magazine,  LTO, Left
303076-001   Magazine,  LTO, Right
252850-001   Module, Adapter  RJ11/DB9F
231674-001   MSL6030 - Module, Backplane
234893-001   MSL6060 - Module, Backplane, Upper
263642-001   MSL6060 - Module, Backplane, Lower
320101-001   Module, Fibre Channel to UltraSCSI 3-160, LVD (e1200-160)
231671-001   Module,  Library Control
331226-001   MSL6030 - Module, Control Panel, Auto-power-on
331227-001   MSL6060 - Module, Control Panel, Auto-power-on
263640-001   Module, Controller, Vertical
231678-001   Module, Front Panel LED
331229-001   Module, Hot-plug/SCSI combo, UltraSCSI 3 (new MSL6000 module)
303072-001   MSL6030 - Opto Sensor Set
303073-001   MSL6060 - Opto Sensor Set
246731-001   Pass Thru Cable, external
246726-001   Pass thru extender 5U
246727-001   Pass thru extender 10U
303051-001   Pass Thru Hub (Router, 9-port)
246728-001   Pass Thru Mechanism (Compaq MSL5026, MSL5052)
303050-001   Pass Thru Mechanism, Universal
234892-001   Power Supply  Receiver w/ bd
231668-001   Power Supply
303071-001   MSL6030 - Robot  w/ Barcode, 5U
303070-001   MSL6060 - Robot  w/ Barcode, 10U
304826-B21   MSL5000 System/e Rackmount Kit (HP Racks)
231894-B22   MSL5000 TT-RM Rackmount Kit, ProLiant Rack
231894-B21   MSL5000 TT-RM Rackmount Kit, Alpha Rack
254795-001   Alpha Rail Kit
263637-001   Screw, Rail, Front (Vertical Axis component, includes Motor)
263638-001   Screw, Rail,  Rear (Vertical Axis component, includes Motor)
231667-001   Solenoid, Door Latch, Set
265362-001   Solenoid,  Magazine
231684-001   MSL6030 - Solenoid, Mail Slot
279245-001   MSL6060 - Solenoid, Mail Slot
331225-001   Tape Drive, 200/400 GB, LTO Ultrium 2, in
