这是什么错误,怎么解决
Error[e16]: Segment CSTACK (size: 0x50 align: 0x1) is too long for segment definition. At least 0x7 more bytes needed. The problem occurred while processing the segment placement command "-Z(DATA)CSTACK+_STACK_SIZE#", where at the moment of placement the available memory ranges were "CODE:9b7-9ff"
Reserved ranges relevant to this placement: |
