我在初始化函数的时候,没有开启任何中断,程序也就是一个简单的串口接收处理,我上传代码,帮忙看看哪里出了问题?- static struct usart_module ext3_uart_module;
- * Configure UART console.
- static void configure_console(void)
- struct usart_config usart_conf;
- usart_get_config_defaults(&usart_conf);
- usart_conf.mux_setting = EXT3_UART_SERCOM_MUX_SETTING ;
- usart_conf.pinmux_pad0 = EXT3_UART_SERCOM_PINMUX_PAD0;
- usart_conf.pinmux_pad1 = EXT3_UART_SERCOM_PINMUX_PAD1;
- usart_conf.pinmux_pad2 = EXT3_UART_SERCOM_PINMUX_PAD2;
- usart_conf.pinmux_pad3 = EXT3_UART_SERCOM_PINMUX_PAD3;
- usart_conf.baudrate = 57600;
- stdio_serial_init(&ext3_uart_module, EXT3_UART_MODULE, &usart_conf); usart_enable(&ext3_uart_module);
- int main(void)
- struct port_config pin;
- uint8_t *tmp_data;
- system_init();
- /*Configure UART console.*/
- configure_console();
- /* Output example information */
- puts(STRING_HEADER);
- /*Configures PORT for LED0*/
- port_get_config_defaults(&pin);
- pin.direction = PORT_PIN_DIR_OUTPUT;
- port_pin_set_config(LED0_PIN, &pin);
- port_pin_set_output_level(LED0_PIN, LED0_INACTIVE);
- /*main loop*/
- while(1)
- usart_serial_getchar(&ext3_uart_module,tmp_data);
while循环中的代码
- static inline void usart_serial_getchar(
- struct usart_module *const module,
- volatile uint8_t *c)
- volatile uint8_t temp = 0;
- SercomUsart *const usart_hw = &(module->hw->USART);
- while(!(usart_hw->INTFLAG.reg & SERCOM_USART_INTFLAG_RXC));
- temp= (volatile uint8_t)(usart_hw->DATA.bit.DATA);
- *c = temp;
现在程序跑起来 经常会进入
- * \brief Default interrupt handler for unused IRQs.
- void Dummy_Handler(void)
- while (1) {
现在也不知道是什么原因导致的!
