TIM2 Configuration: Output Compare Timing Mode:
TIM2CLK = 36 MHz, Prescaler = 4, TIM2 counter clock = 36/(1+4)=7.2 MHz
CC1 update rate = TIM2 counter clock / CCR1_Val = 146.48 Hz
CC2 update rate = TIM2 counter clock / CCR2_Val = 219.7 Hz
CC3 update rate = TIM2 counter clock / CCR3_Val = 439.4 Hz
CC4 update rate = TIM2 counter clock / CCR4_Val = 878.9 Hz
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 0;这里有一个预分频参数
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Prescaler configuration */
TIM_PrescalerConfig(TIM2, 4, TIM_PSCReloadMode_Immediate);这里也有一个预分频参数
请问两个预分频参数区别在哪里?
还有TIM_TimeBaseStructure.TIM_ClockDivision = 0;这个参数具体作用是什么? |
