咦 代码怎么只有这一点
再来
- UINT8 xReadCH376Data( void ) /* 从CH376读数据 */
- INT8U ch;
- while(SCI0SR1_RDRF == 0) { /* Is the transmitter empty? */
- ch=SCI0DRL;
- return ch;
- unsigned char datatest=0x65;
- //unsigned char datarecv;
- DatMov g_DatProcess; //回调函数指针
- INT8U init_ch376s(DatMov pFunc){
- volatile UINT8 res1=0;
- if(pFunc==NULL){ return;}
- g_DatProcess=pFunc;
- Init_SCI0(InitBaud); //376的默认波特率9600
- xWriteCH376Cmd( CMD11_CHECK_EXIST );
- xWriteCH376Data(datatest);
- res1=xReadCH376Data();
- LED=0b11111110;
- if (res1 != 0x9A ){return (ERR_USB_UNKNOWN );}
- /* xWriteCH376Cmd( CMD21_SET_BAUDRATE ); //设置串口通讯波特率
- #if UART_WORK_BAUDRATE >= 6000000/256
- xWriteCH376Data( 0x03 );
- xWriteCH376Data( 256 - 6000000/UART_WORK_BAUDRATE );
- #else
- xWriteCH376Data( 0x02 );
- xWriteCH376Data( 256 - 750000/UART_WORK_BAUDRATE );
- #endif
- Init_SCI0(WorkBaud); //设置单片机工作波特率与CH376s相同
- LED=0b11111100;
- res1 = xReadCH376Data( );
- if( res1 != CMD_RET_SUCCESS ) return( ERR_USB_UNKNOWN ); */ // 设置模式错误
- xWriteCH376Cmd( CMD11_SET_USB_MODE ); //设备USB工作模式
- xWriteCH376Data( 0x06 );
- LED=0b11111100;
- if ( res1 != CMD_RET_SUCCESS ) { return 0x02; }
- Drv_INT0Interrupt(); //使能IRQ中断
- Sys_SemCreate(&sem_ch376, 0); //创建信号量 sem_key
- Sys_CreateTask(TASK_ID_CH376, Ch376Task, 0);
- return (USB_INT_SUCCESS);
