[i.MX] imx6q ubuntu12.04 x64 ltib编译出错,请大虾帮忙看一下,多谢!
1147|2
 楼主| ZM_Caesar 发表于 2016-4-9 21:49 | 显示全部楼层 |阅读模式
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /lib/libc.so.6
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /usr/lib/libc_nonshared.a
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /lib/ld-linux.so.3
collect2: ld returned 1 exit status
make: *** [busybox_unstripped] Error 1
error: Bad exit status from /home/derrick/ltib/ltib/tmp/rpm-tmp.18080 (%build)
RPM build errors:
Build time for busybox: 87 seconds
Failed building busybox
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Apr  8 16:52:45 2016
Ended:   Fri Apr  8 18:25:55 2016
Elapsed: 5590 seconds
These packages failed to build:
busybox
Build Failed
Exiting on error or interrupt
derrick@ubuntu:~/ltib/ltib$
kuaijie00 发表于 2016-4-20 16:24 | 显示全部楼层
我也遇到了这个问题啊,同样提示找不到那三个文件。。。。
请问你解决了嘛?
mini1986 发表于 2016-5-5 10:00 | 显示全部楼层
目测,你们没有装32bit的库......
