[STM32F1] stm32的AD采集问题
1222|6
 楼主| zhang3721 发表于 2016-4-15 09:21 | 显示全部楼层 |阅读模式
最近需要用到两个ADC对两路AD进行同步采样,用TIM3来设置采样率,DMA来传输采集结果,但是出现了每采集的1024个点,前252个点均为0,求助!!
附上程序:
void ADC1_2_Config(u16 SampleFreq,u16 DMA_BufferSizer)
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
TIM_TimeBaseInitTypeDef   TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_ADCCLKConfig(RCC_PCLK2_Div2);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//定时器3控制采样率
TIM_TimeBaseStructure.TIM_Prescaler= 0;
TIM_TimeBaseStructure.TIM_CounterMode= TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period= 72000000 / SampleFreq - 1;
TIM_TimeBaseStructure.TIM_ClockDivision= 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit( TIM3, &TIM_TimeBaseStructure);
TIM_SelectOutputTrigger( TIM3, TIM_TRGOSource_Update );
TIM_ARRPreloadConfig(TIM3,ENABLE);
TIM_Cmd( TIM3, ENABLE );
DMA_DeInit(DMA1_Channel1);                                                   //DMA通道1恢复到默认状态
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;        //设置数据来源地址
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_DualConvertedValueTab;  //设置copy目标地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;                           //设置copy方向
DMA_InitStructure.DMA_BufferSize = ADC_BufferLength;                                       //设置数组大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;             //数据来源不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                      //数据保存的数组地址自增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;      //DMA操作字长 32位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;              //DMA操作字长 32位
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                //普通的DMA操作模式:当DMA操作转移够 数组大小        //所限定的数据总量后,则不再进行DMA操作
DMA_InitStructure.DMA_Priority = DMA_Priority_High;                          //DMA优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                                 //关闭mTM
DMA_Init(DMA1_Channel1, &DMA_InitStructure);                                 //使能dma
/* Enable DMA1 Channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
/* DMA Transfer Complete Interrupt enable */
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;   //通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //占先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        //响应级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;           //启动
NVIC_Init(&NVIC_InitStructure);                           //初始化
DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
/* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult;                              //ADC1同步规则组模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE;                                  //启动扫描
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;                            //连续转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO;           //无外部触发
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                        //结果右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1;                                       //转换通道数2
ADC_Init(ADC1, &ADC_InitStructure);                                           //配置ADC1
/* ADC1 regular channels configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_28Cycles5); //通道配置
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* ADC2 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult;                              //ADC2同步规则组模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;           //无外部触发
ADC_Init(ADC2, &ADC_InitStructure);                                           //配置ADC2
/* ADC2 regular channels configuration */
ADC_RegularChannelConfig(ADC2, ADC_Channel_4, 1, ADC_SampleTime_28Cycles5); //通道配置
/* Enable ADC2 external trigger conversion */
ADC_ExternalTrigConvCmd(ADC2, ENABLE);                                        //使能ADC2的外部触发模式
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);                                                        //使能ADC1
/* Enable Vrefint channel17 */
// ADC_TempSensorVrefintCmd(ENABLE);                                             // 使能温度传感器内部参考电压通道
/* Enable ADC1 reset calibration register */
ADC_ResetCalibration(ADC1);                                                   //ADC1的校准
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibration */
ADC_StartCalibration(ADC1);
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));
/* Enable ADC2 */
ADC_Cmd(ADC2, ENABLE);                                                      //使能ADC2
/* Enable ADC2 reset calibration register */
ADC_ResetCalibration(ADC2);                                                 //ADC2的校准
/* Check the end of ADC2 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC2));
/* Start ADC2 calibration */
ADC_StartCalibration(ADC2);
/* Check the end of ADC2 calibration */
while(ADC_GetCalibrationStatus(ADC2));
/* Start ADC1 Software Conversion */                                        //软件启动ADC1,开始转换
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
// while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
// /* Clear DMA1 channel1 transfer complete flag */
// DMA_ClearFlag(DMA1_FLAG_TC1);
// DMA_Done = 1;
void DMA1_Channel1_IRQHandler(void)
if(DMA_GetITStatus(DMA1_IT_TC1) != RESET)
DMA_ClearITPendingBit(DMA1_IT_TC1);
DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,DISABLE);
ADC_Cmd(ADC1,DISABLE);
ADC_Cmd(ADC2,DISABLE);
DMA_Done =1;
采集结果
ticomi 发表于 2016-4-15 09:48 | 显示全部楼层
确定开始采集时ADC已经开始转换数据了?
玄德 发表于 2016-4-15 09:55 | 显示全部楼层
先启动DMA,然后才配置AD?
 楼主| zhang3721 发表于 2016-4-15 10:16 | 显示全部楼层
先启动DMA,然后才配置AD?
官方例程就是这样的
xmshao 发表于 2016-4-15 12:05 | 显示全部楼层
你适当调整下初始化配置顺序 测试下
ADC  ===》 DMA  ===》TIMER
TIMER更新事件触发ADC,ADC触发DMA传输。
OldMouth 发表于 2016-4-16 20:55 | 显示全部楼层
5楼正解!
Thethree 发表于 2016-4-16 21:38 | 显示全部楼层
你采集的数据存放的数组是多大的啊,开始的时候估计是没采集够就开始显示了
