| 接收串口发送过来的数字,0X80输出第一路方波,0X81输出第二路方波#include"reg51.h"
 sbit OUT0=P1^0;
 sbit OUT1=P1^1;
 unsigned char T0_flag,Com_flag;
 unsigned char ch;
 void PWM0(unsigned char count);
 void PWM1(unsigned char count);
 void init_T0(void);
 void init_Com(void);
 main()
 init_T0();
 init_Com();
 T0_flag=0;
 Com_flag=0;
 while(1)
 while(Com_flag==0);
 Com_flag=0;
 switch(ch)
 case 0x80:  //0号方波输出
 PWM0(20);  //  50Hz
 break;
 case 0x81:
 PWM1(10); //100Hz
 break;
 default:
 break;
 TR0=1;
 while(1)
 while(T0_flag==0);
 T0_flag=0;
 count--;
 if(count==0) OUT0=~OUT0;
 if(Com_flag==1)
 TR0=0;
 break;
 TR0=1;
 while(1)
 while(T0_flag==0);
 T0_flag=0;
 count--;
 if(count==0) OUT1=~OUT1;
 if(Com_flag==1)
 TR0=0;
 break;
 void init_T0(void)
 TMOD|=0x01;
 TH0=0xfc;
 TL0=0x17;
 EA=1;
 ET0=1;
 void isr_T0(void) interrupt 1 using 2 //1MS
 TH0=0xfc;
 TL0=0x17;
 T0_flag=1;
 void init_Com(void)
 SCON=0x50;
 TMOD|=0x20;
 PCON|=0x80;
 TH1=0xf4;
 IE|=0x90;
 TR1=1;
 void isr_Com(void) interrupt 4 using 3 //串口中断
 if(RI)
 RI=0;
 ch=SBUF;
 Com_flag=1;
