- 1 /* 定义了对话框资源列表 */
- 2 static const GUI_WIDGET_CREATE_INFO aDialogCreate[] = {
- 3 //建立窗体, 大小是800X480 原点在0,0
- 4 { FRAMEWIN_CreateIndirect, "http://beautifulzzzz", 0,0,0, 800, 480, FRAMEWIN_CF_ACTIVE },
- 5 { BUTTON_CreateIndirect, "SEND", GUI_ID_BUTTON0, 0, 395, 200, 55 },
- 6
- 7 { BUTTON_CreateIndirect, "CLEAR", GUI_ID_BUTTON2, 200, 395, 200, 55 },
- 8 { EDIT_CreateIndirect, "", GUI_ID_EDIT1, 0, 190, 400, 65, EDIT_CF_LEFT, 50 },
- 9 { EDIT_CreateIndirect, "", GUI_ID_EDIT2, 0, 290, 400, 65, EDIT_CF_LEFT, 50 },
- 10
- 11 //建立TEXT控件,起点是窗体的X,X,大小XXY 文字左对齐
- 12 { TEXT_CreateIndirect, "Send Text Area", GUI_ID_TEXT0, 1, 160, 400, 25, TEXT_CF_LEFT },
- 13 { TEXT_CreateIndirect, "Receive Text Area ", GUI_ID_TEXT1, 1, 263, 400, 25, TEXT_CF_LEFT },
- 14
- 15 { TEXT_CreateIndirect, "2M bps", GUI_ID_TEXT2, 23, 22, 140, 25, TEXT_CF_LEFT },
- 16 { TEXT_CreateIndirect, "1M bps", GUI_ID_TEXT3, 23, 42, 140, 25, TEXT_CF_LEFT },
- 17 { TEXT_CreateIndirect, "250K bps", GUI_ID_TEXT5, 23, 62, 140, 25, TEXT_CF_LEFT },
- 18
- 19 { TEXT_CreateIndirect, "", GUI_ID_TEXT4, 0, 120, 400, 25, TEXT_CF_LEFT },
- 20
- 21 { RADIO_CreateIndirect, "Receive Mode", GUI_ID_RADIO0, 3, 33, 40, 52, RADIO_TEXTPOS_LEFT,3},
- 22
- 23 { LISTBOX_CreateIndirect, "", GUI_ID_LISTBOX0, 134, 13, 130, 90, 0, 0 },
- 24
- 25 //建立滑块
- 26 { SLIDER_CreateIndirect, NULL, GUI_ID_SLIDER1, 440, 60, 320, 25, 0, 0 },
- 27 { SLIDER_CreateIndirect, NULL, GUI_ID_SLIDER2, 440, 120, 320, 25, 0, 0 },
- 28 { SLIDER_CreateIndirect, NULL, GUI_ID_SLIDER3, 440, 180, 320, 25, 0, 0 },
- 29 { SLIDER_CreateIndirect, NULL, GUI_ID_SLIDER4, 440, 240, 320, 25, 0, 0 },
- 30 { SLIDER_CreateIndirect, NULL, GUI_ID_SLIDER5, 440, 300, 320, 25, 0, 0 },
- 31 //建立滑块对应的text
- 32 { TEXT_CreateIndirect, "0", GUI_ID_TEXT_SPEED1, 770, 60, 25, 25, TEXT_CF_LEFT },
- 33 { TEXT_CreateIndirect, "0", GUI_ID_TEXT_SPEED2, 770, 120, 25, 25, TEXT_CF_LEFT },
- 34 { TEXT_CreateIndirect, "0", GUI_ID_TEXT_SPEED3, 770, 180, 25, 25, TEXT_CF_LEFT },
- 35 { TEXT_CreateIndirect, "0", GUI_ID_TEXT_SPEED4, 770, 240, 25, 25, TEXT_CF_LEFT },
- 36 { TEXT_CreateIndirect, "0", GUI_ID_TEXT_SPEED5, 770, 300, 25, 25, TEXT_CF_LEFT },
- 37 };
还要回过头说说我们的USART和NRF24L01,他们的初始化要看main函数中的BSP_Init();函数,该函数负相关硬件的初始化设置(中文意思是板级支持包初始化函数,因为uc-OS可以并不只限于stm32单片机,所以这里要根据不同平台进行相应的设置)。该函数位于bsp.c函数中,其作用相当于将以前我们在main函数中进行的相关硬件初始化单独拿出来封装成一个函数而已~但是,串口和无线对应的中断接收程序却有点不一样,因为这里是操作系统,所以在每个中断子程序前要调用OS_ENTER_CRITICAL();保存当前的全局中断标志,然后OSIntNesting++;中断嵌套深度加1,最后调用OS_EXIT_CRITICAL();恢复全局中断标志进入正常的中断处理,此外在中断响应函数最后要调用OSIntExit(); 检测如果有更高优先级的任务就绪了,则执行一次任务切换。
串口和无线中断子程序- /*******************************************************************************
- * Function Name : USART1_IRQHandler
- * Description : This function handles USART1 global interrupt request.
- * Input : None
- * Output : None
- * Return : None
- void USART1_IRQHandler(void)
- unsigned int i;
- OS_CPU_SR cpu_sr;
- OS_ENTER_CRITICAL(); //保存全局中断标志,关总中断 Tell uC/OS-II that we are starting an ISR
- OSIntNesting++;
- OS_EXIT_CRITICAL(); //恢复全局中断曛?
- if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //判断读寄存器是否非空
- RxBufferUSART[RxCounter1++] = USART_ReceiveData(USART1); //将读寄存器的数据缓存到接收缓冲区里
- if(RxBufferUSART[RxCounter1-2]==0x0d&&RxBufferUSART[RxCounter1-1]==0x0a) //判断结束标志是否是0x0d 0x0a
- for(i=0; i< RxCounter1; i++) TxBufferRF[i] = RxBufferUSART[i]; //将接收缓冲器的数据转到发送缓冲区,准备转发
- usart_rec_flag=1; //接收成功标志
- TxBufferRF[RxCounter1]=0; //发送缓冲区结束符
- TxCounter1=RxCounter1;
- RxCounter1=0;
- if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET) //这段是为了避免STM32 USART 第一个字节发不出去的BUG
- USART_ITConfig(USART1, USART_IT_TXE, DISABLE); //禁止发缓冲器空中断,
- OSIntExit(); //在os_core.c文件里定义,如果有更高优先级的任务就绪了,则执行一次任务切换
- void EXTI0_IRQHandler(void)
- unsigned char status,i;
- OS_CPU_SR cpu_sr;
- OSIntNesting++;
- OS_EXIT_CRITICAL(); //恢复全局中断标志
- if(EXTI_GetITStatus(EXTI_Line0) != RESET) //判断是否产生了EXTI0中断
- if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0){ //判断是否是PA0线变低
- status=SPI_Read(READ_REG1+STATUS); // 读取状态寄存其来判断数据接收状况
- if(status & 0x40) // 判断是否接收到数据
- SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH); //从接收缓冲区里读出数据
- for(i=0; i<32; i++){ //向USB 端点1的缓冲区里放置数据
- TxBufferUSART[i] = rx_buf[i];
- rf_rec_flag=1;
- if((status&0x0e)<=0x0a){
- nrf_Pipe_r=(status&0x0e)>>1; //读出是在哪个通道接收的
- else nrf_Pipe_r=0;
- Rx_Succ=1; //读取数据完成标志
- /* 根据读出的接收通道号,将相应信息写入状态文本缓冲区 */
- if(nrf_Pipe_r==0) memcpy(status_buf, "Pipe 0 Recive OK! ", 20);
- else if(nrf_Pipe_r==1) memcpy(status_buf, "Pipe 1 Recive OK! ", 20);
- else if(nrf_Pipe_r==2) memcpy(status_buf, "Pipe 2 Recive OK! ", 20);
- else if(nrf_Pipe_r==3) memcpy(status_buf, "Pipe 3 Recive OK! ", 20);
- else if(nrf_Pipe_r==4) memcpy(status_buf, "Pipe 4 Recive OK! ", 20);
- else if(nrf_Pipe_r==5) memcpy(status_buf, "Pipe 5 Recive OK! ", 20);
- else if((status &0x10)>0){ //发射达到最大复发次数
- SPI_RW_Reg(0xe1,0); //清除发送缓冲区
- RX_Mode(); //进入接收模式
- Rx_Succ=1;
- /* 根据发送通道,将相应信息写入状态文本缓冲区 */
- if(nrf_Pipe==0) memcpy(status_buf, "Pipe 0 NO ACK! ", 20);
- else if(nrf_Pipe==1) memcpy(status_buf, "Pipe 1 NO ACK! ", 20);
- else if(nrf_Pipe==2) memcpy(status_buf, "Pipe 2 NO ACK! ", 20);
- else if(nrf_Pipe==3) memcpy(status_buf, "Pipe 3 NO ACK! ", 20);
- else if(nrf_Pipe==4) memcpy(status_buf, "Pipe 4 NO ACK! ", 20);
- else if(nrf_Pipe==5) memcpy(status_buf, "Pipe 5 NO ACK! ", 20);
- else if((status &0x20)>0){ //发射后收到应答
- Rx_Succ=1;
- if(nrf_Pipe==0) memcpy(status_buf, "Pipe 0 Send OK! ", 20);
- else if(nrf_Pipe==1) memcpy(status_buf, "Pipe 1 Send OK! ", 20);
- else if(nrf_Pipe==2) memcpy(status_buf, "Pipe 2 Send OK! ", 20);
- else if(nrf_Pipe==3) memcpy(status_buf, "Pipe 3 Send OK! ", 20);
- else if(nrf_Pipe==4) memcpy(status_buf, "Pipe 4 Send OK! ", 20);
- else if(nrf_Pipe==5) memcpy(status_buf, "Pipe 5 Send OK! ", 20);
- SPI_RW_Reg(WRITE_REG1+STATUS, status); //清除07寄存器标志
- EXTI_ClearITPendingBit(EXTI_Line0); //清除EXTI0上的中断标志
- 串口和无线中断子程序
最后说明
对于纯玩软件的小伙伴,这里涉及的东西有点多,不必细究,看看了解即可。但是对于初学stm32,尤其是还在为stm32控制NRF24L01不通的同学,这个还是挺有用滴~下面有工程的链接,里面有些注释不规范,一切以我博客里说的为准哦~
