PSOC3 VCCD 有什么用,不是太明白datasheet上表达的意思??
3492|8
 楼主| rocky_bian 发表于 2009-12-12 16:26 | 显示全部楼层 |阅读模式
贾君鹏子 发表于 2009-12-12 21:30 | 显示全部楼层
没怎么用过
god_like 发表于 2009-12-12 23:18 | 显示全部楼层
进来学习
love_life 发表于 2009-12-12 23:35 | 显示全部楼层
没用过
jxin 发表于 2009-12-13 08:36 | 显示全部楼层
数字模块电源啊
beny5566 发表于 2009-12-13 20:55 | 显示全部楼层
看说明书要仔细,呵呵。
Go_PSoC 发表于 2009-12-13 22:02 | 显示全部楼层
psoc3的电源引脚是不少,要仔细看一下datasheet,不然真有点糊涂,呵呵
Vboost. Power sense connection to boost pump.
Vbat. Battery supply to boost pump.
Vcca. Output of analog core regulator and input to analog core.Requires a 1 µF cap to Vssa. Regulator output not for external use
Vccd. Output of digital core regulator and input to digital core.Requires a 1 µF cap to Vssd. Regulator output not for external use
Vdda. Supply for all analog peripherals and analog core regulator. Vdda must be the highest voltage present on the device. All other supply pins must be less than or equal to Vdda
Vddd. Supply for all digital peripherals and digital core regulator.Vddd must be less than or equal to Vdda.
Vssa. Ground for all analog peripherals.
Vssb. Ground connection for boost pump.
Vssd. Ground for all digital logic and I/O pins.
Vddio0, Vddio1, Vddio2, Vddio3. Supply for I/O pins. See pinouts for specific I/O pin to Vddio mapping. Vddio must be less than or equal to Vdda.
Apnote 发表于 2009-12-15 11:27 | 显示全部楼层
Vccd是芯片内部的1.8V regulators产生,供给芯片内部的数字逻辑模块。
 楼主| rocky_bian 发表于 2009-12-16 18:10 | 显示全部楼层
谢谢,各位的帮忙
