WinCE 6.0 内核编译时出错误,是啥问题
6479|5
 楼主| robinyuan 发表于 2010-1-1 22:45 | 显示全部楼层 |阅读模式
BUILD: [01:0000000621:WARNN ] C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\DISPLAY\DISPLAY_DRV\.\blt_alpha.cpp(283) : warning C4101: 'rectFullCloneDst' : unreferenced local variable
BUILD: [01:0000000622:WARNN ] C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\DISPLAY\DISPLAY_DRV\.\blt_alpha.cpp(282) : warning C4101: 'rectFullOrgDst' : unreferenced local variable
BUILD: [01:0000000623:PROGC ] Compiling .\surf.cpp
BUILD: [01:0000000626:PROGC ] Compiling .\halcaps.cpp
BUILD: [01:0000000629:ERRORE] C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\DISPLAY\DISPLAY_DRV\.\halcaps.cpp(176) : error C2065: 'DDHALINFO_FOURCCINFORMATION' : undeclared identifier
BUILD: [01:0000000630:PROGC ] Compiling .\haldd.cpp
BUILD: [01:0000000633:PROGC ] Compiling .\halsurf.cpp
BUILD: [01:0000000636:PROGC ] Compiling .\tvcontrol.cpp
BUILD: [00:0000000639:PROGC ]                        Files  Warnings  Errors
BUILD: [00:0000000640:PROGC ] Midl                       0         0       0
BUILD: [00:0000000641:PROGC ] Message                    0         0       0
BUILD: [00:0000000642:PROGC ] Precomp Header             2         0       0
BUILD: [00:0000000643:PROGC ] Resource                   0         0       0
BUILD: [00:0000000644:PROGC ] MASM                       0         0       0
BUILD: [00:0000000645:PROGC ] SHASM                      0         0       0
BUILD: [00:0000000646:PROGC ] ARMASM                     2         6       0
BUILD: [00:0000000647:PROGC ] MIPSASM                    0         0       0
BUILD: [00:0000000648:PROGC ] C++                       17         2       1
BUILD: [00:0000000649:PROGC ] C                         33         0       0
BUILD: [00:0000000650:PROGC ] Static Libraries           0         0       0
BUILD: [00:0000000651:PROGC ] Exe's                      0         0       0
BUILD: [00:0000000652:PROGC ] Dll's                      0         0       0
BUILD: [00:0000000653:PROGC ] Preprocess deffile         0         0       0
BUILD: [00:0000000654:PROGC ] Resx                       0         0       0
BUILD: [00:0000000655:PROGC ] CSharp Compile             0         0       0
BUILD: [00:0000000656:PROGC ] Other                      0         1       1
BUILD: [00:0000000657:PROGC ]
BUILD: [00:0000000658:PROGC ] Total                     54         9       2
BUILD: [00:0000000659:PROGC ]
BUILD: [00:0000000660:PROGC ] 9 Warnings,  2 Errors
BUILD: [00:0000000661:PROGC ] GetSystemTimes (seconds): Idle: 3     Kernel: 22    User: 29
BUILD: [00:0000000662:PROGC ] Elapsed  time  (seconds): 51
Build for Windows CE (Release 601) (Built on Aug 17 2006 15:18:52)
File names: Build.log Build.wrn Build.err Build.dat
Sysgening platform C:\WINCE600\platform\SMDK6410
\WINCE600\build.err
BLDDEMO: There were errors building Real6410V1
Real6410V1 - 2 error(s), 14 warning(s)
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
编了2个小时,结果不成功,winCE6.0 R3的包我没有安装,跟这个有没有关系
high 发表于 2010-1-2 00:59 | 显示全部楼层
hi, robinyuan,我已经在 学者之家 论坛 答复过你。
请打上 09年02月的补丁
 楼主| robinyuan 发表于 2010-1-3 00:22 | 显示全部楼层
呵呵,已经搞定了,谢谢楼上的回复
hkhu 发表于 2010-8-18 21:43 | 显示全部楼层
09年02月的补丁是什么啊???
lovereplicate 发表于 2013-9-16 09:35 | 显示全部楼层
同问这个补丁是?
个人签名:http://www.hotpage.net.cn/
36
