原理图也有!焊接介绍也有,可为什么就是下载不了程序???为什么呢?我不知道有没有焊错,那水晶插口哪里,MPLAB 的提示是:
Programming Target...
ICDWarn0052: MPLAB ICD 2 cannot validate a target device. Please make sure that the target device is connected and properly powered. Select "OK" to continue, or "CANCEL" to abort the operation
...Validating configuration fields
...Erasing Part
Verifying...
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Failed (and stopped)
ICD0161: Verify failed (MemType = Config, Address = 0xFFF, Expected Val = 0xFFF, Val Read = 0x0)
ICD0275: Programming failed.
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Verify Succeeded
.. Config Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Verify Succeeded
.. Config Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Verify Succeeded
.. Config Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Verify Succeeded
.. Config Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Verify Succeeded
.. Config Memory
MPLAB ICD 2 Ready |
