NUC140管脚排列
3062|1
 楼主| agnd 发表于 2010-3-7 19:17 | 显示全部楼层 |阅读模式
准备开始设计NUC140芯片的应用板了,根据最新的数据手册V1.10版,整理了一下各种封装的管脚排列
100P    64P    48P       管脚功能
1                       PE.15
2                       PE.14
3                       PE.13
4       1               INT0/SS31#/PB.14
5       2               CPO_1/PB.13
6       3      1        CPO_0/PB.12
7       4      2        X32_I
8       5      3        X32_O
9       6      4        I2C1_SCL/PA.11
10       7      5        I2C1_SDA/PA.10
11       8      6        I2C0_SCL/PA.9
12       9      7        I2C0_SDA/PA.8
13                       SS30#/PD.8
14                       SPICLK3/PD.9
15                       MISO3_0/PD.10
16                       MOSI3_0/PD.11
17                       MISO3_1/PD.12
18                       MOSI3_1/PD.13
19      10      8        RX1/PB.4
20      11      9        TX1/PB.5
21      12               RTS1/PB.6
22      13               CTS1/PB.7
23      14     10        LDO(LDO_OUT)
24      15     11        VDD(LDO_IN_5V)
25      16     12        VSS
26                       PE.8
27                       PE.7
28                       VBUS(USB_LDO_IN_5V)
29                       VDD33(USB_LDO33_OUT)
30                       USB_D-
31                       USB_D+
32      17     13        RX0 /PB.0
33      18     14        TX0 /PB.1
34      19     15        RTS0/PB.2
35      20     16        CTS0/PB.3
36      21     17        CAN_RX0/PD.6
37      22     18        CAN_TX0/PD.7
38      23     19        RX2/PD.14
39      24     20        TX2/PD.15
40                       MOSI0_1/PC.5
41                       MISO0_1/PC.4
42      25     21        MOSI0_0/I2SDO/PC.3
43      26     22        MISO0_0/I2SDI/PC.2
44      27     23        SPICLK0/I2SBCLK/PC.1
45      28     24        SS00#/I2SLRCLK/PC.0
46                       PE.6
47      29               PWM5/PE.5
48      30               TM3/PWM4/PB.11
49      31               TM2/SS01#/PB.10
50      32               TM1/SS11#/PB.9
51                       PE.4
52                       PE.3
53                       PE.2
54                       PWM7/PE.1
55                       PWM6/PE.0
56                       MOSI1_1/PC.13
57                       MISO1_1/PC.12
58      33               MOSI1_0/PC.11
59      34               MISO1_0/PC.10
60      35               SPICLK1/PC.9
61      36               SS10#/PC.8
62      37     25        PWM3/I2SMCLK/PA.15
63      38     26        PWM2/PA.14
64      39     27        PWM1/PA.13
65      40     28        PWM0/PA.12
66      41     29        ICE_DAT
67      42     30        ICE_CLK
68                       VDD2
69                       VSS2
70      43     31        AVSS
71      44     32        ADC0/PA.0
72      45     33        ADC1/PA.1
73      46     34        ADC2/PA.2
74      47     35        ADC3/PA.3
75      48     36        ADC4/PA.4
76      49     37        ADC5/PA.5
77      50     38        ADC6/PA.6
78      51     39        ADC7/SS21#/PA.7
79                       VREF
80      52     40        AVDD
81                       SS20#/PD.0
82                       SPICLK2/PD.1
83                       MISO2_0/PD.2
84                       MOSI2_0/PD.3
85                       MISO2_1/PD.4
86                       MOSI2_1/PD.5
87      53     41        CPN0/PC.7
88      54     42        CPP0/PC.6
89      55               CPN1/PC.15
90      56               CPP1/PC.14
91      57     43        INT1#/PB.15
92      58     44        XT1_OUT
93      59     45        XT1_IN
94      60     46        RESET#
95      61               VSS1
96      62               VDD1(LDO_IN_5V)
97                       PS2DAT
98                       PS2CLK
99      63     47        PVSS
100     64     48        STADC/TM0/PB.8
 楼主| agnd 发表于 2010-3-8 14:29 | 显示全部楼层
无语
