[技术问答] MINI58蕊片的SPI输出测试
2545|7
 楼主| dragonjun 发表于 2016-6-12 09:46 | 显示全部楼层 |阅读模式
我配的在MINI58下SPI输出用逻辑分析仪测不到波形,大家看下有错误吗
其中串口能用软件看到打印输出,但蕊片MOSI、MISO口测不到波形
int main(void)
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART for printf */
    UART_Init();
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                       SPI Driver Sample Code                         |\n");
    printf("\n");
    printf(" Please Connect:\n");
    printf(" P0.5 MOSI <--> P0.6 MISO \n");
    //SpiLoopbackTest();
    while(1)
                        SPI_READ_RX(SPI0);
                        SPI_WRITE_TX(SPI0, 0xaa);
//    return 0;
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Read User Config to select internal high speed RC */
    //SystemInit();
    /* Init System Clock        */
    /* Enable external 12MHz XTAL, HIRC */
   // CLK->PWRCTL |= CLK_PWRCTL_XTL12M | CLK_PWRCTL_HIRCEN_Msk;
    /* Waiting for clock ready */
   // CLK_WaitClockReady(CLK_STATUS_XTLSTB_Msk | CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to XTL */
   // CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_XTAL,CLK_CLKDIV_HCLK(1));
    /* STCLK to XTL STCLK to XTL */
   // CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_XTAL);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(SPI0_MODULE);
                SystemCoreClockUpdate();
    /* Select IP clock source */
   // CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UARTSEL_XTAL,CLK_CLKDIV_UART(1));
    //CLK_SetModuleClock(SPI0_MODULE,CLK_CLKSEL1_SPISEL_XTAL,0);
    /* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD and TXD */
    SYS->P5_MFP = SYS_MFP_P51_UART0_RXD | SYS_MFP_P50_UART0_TXD;
    /* Setup SPI multi-function pin */
    SYS->P0_MFP |= SYS_MFP_P04_SPI0_SS | SYS_MFP_P05_SPI0_MOSI | SYS_MFP_P06_SPI0_MISO | SYS_MFP_P07_SPI0_CLK;
    /* Lock protected registers */
    SYS_LockReg();
    /* Update System Core Clock */
   // SystemCoreClockUpdate();
void UART_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART and set UART Baudrate */
    UART_Open(UART0, 115200);
void SPI_Init(void)
    /* Init SPI        */
    /* Configure as a master, clock idle low, falling clock edge Tx, rising edge Rx and 32-bit transaction */
    /* Set IP clock divider. SPI clock rate = 2MHz */
    SPI_Open(SPI, SPI_MASTER, SPI_MODE_0, 32, 2000000);
    /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI, SPI_SS, SPI_SS_ACTIVE_LOW);
mintspring 发表于 2016-6-12 11:20 | 显示全部楼层
能否正常通过测试?
598330983 发表于 2016-6-12 15:57 | 显示全部楼层
楼主这个是SPI跟什么通信的
 楼主| dragonjun 发表于 2016-6-12 16:02 | 显示全部楼层
公司有板子,上面有MINI58蕊片,是一个用来读卡的板子,
我的程序就下到板子上执行,用电脑软件测试
捉虫天师 发表于 2016-7-30 16:27 | 显示全部楼层
对的,既然执行没问题,肯定没问题,另外BSP包邮例程,看看配置一致不。
稳稳の幸福 发表于 2016-7-30 16:57 | 显示全部楼层
初始化应该没问题的,楼主这个芯片玩的咋样了
玛尼玛尼哄 发表于 2016-7-30 17:37 | 显示全部楼层
时钟配置必须搞对。
wahahaheihei 发表于 2016-7-30 18:15 | 显示全部楼层
SPI通信必须配置正确才好用,要不就自己用IO模拟。
