[STM32L1] STM32L151下使用硬件RTC的问题
4109|9
 楼主| jacklow 发表于 2016-6-20 17:57 | 显示全部楼层 |阅读模式
CPU采用了STM32L151C8T6,外接32768Hz晶体LSE, 和8Mhz的HSE,HSE作为时钟工作正常,现在想使用硬件RTC,参考STM32L1xx_StdPeriph_Lib_V1.3.1的例子中提供的初始化代码,运行时却不正常,代码如下:
void RCC_Configuration(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  /* Allow access to RTC Domain */
  PWR_RTCAccessCmd(ENABLE);
  /* Check if the StandBy flag is set */
  if (PWR_GetFlagStatus(PWR_FLAG_SB) != RESET)
    /* Clear StandBy flag */
    PWR_ClearFlag(PWR_FLAG_SB);
    /* Turn on LED2 */
    //STM_EVAL_LEDOn(LED2);
    /* Wait for RTC APB registers synchronisation */
    RTC_WaitForSynchro();
    /* No need to configure the RTC as the RTC config(clock source, enable,
       prescaler,...) are kept after wake-up from STANDBY */
  else
    /* RTC Configuration ******************************************************/
    /* Reset RTC Domain */
    RCC_RTCResetCmd(ENABLE);
    RCC_RTCResetCmd(DISABLE);
    /* Enable the LSE OSC */
    RCC_LSEConfig(RCC_LSE_ON);
    /* Wait till LSE is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
    /* Select the RTC Clock Source */
    RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
    /* Enable the RTC Clock */
    RCC_RTCCLKCmd(ENABLE);
    /* Set the RTC time base to 1s */
    RTC_InitStructure.RTC_HourFormat = RTC_HourFormat_24;
    RTC_InitStructure.RTC_AsynchPrediv = 0x7F;
    RTC_InitStructure.RTC_SynchPrediv = 0x00FF;
    RTC_Init(&RTC_InitStructure);
    /* Set the time to 01h 00mn 00s AM */
    RTC_TimeStructure.RTC_H12     = RTC_H12_AM;
    RTC_TimeStructure.RTC_Hours   = 0x01;
    RTC_TimeStructure.RTC_Minutes = 0x00;
    RTC_TimeStructure.RTC_Seconds = 0x00;
    RTC_SetTime(RTC_Format_BCD, &RTC_TimeStructure);
  /* Clear RTC Alarm A flag */
  RTC_ClearFlag(RTC_FLAG_ALRAF);
void SysTickConfig(void)
  /* SysTick interrupt each 250 ms with SysTick Clock equal to 4MHz */
  if (SysTick_Config((SystemCoreClock/8) / 4))
    /* Capture error */
    while (1);
  /* Select AHB clock(HCLK) divided by 8 as SysTick clock source */
  SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
  /* Set SysTick Preemption Priority to 1 */
  NVIC_SetPriority(SysTick_IRQn, 0x04);
int main(void)
        RCC_Configuration();
        PWR_WakeUpPinCmd(PWR_WakeUpPin_1, ENABLE);
          /* Configure the SysTick to generate an interrupt each 250 ms */
          SysTickConfig();
          while (1)
程序运行死在了RCC_Configuration,断点跟踪发现死在 while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET) 中,这是为何,仔细检查外围电路没发现异常,不知道哪位遇到过同样问题,是如何解决的?
Thethree 发表于 2016-6-20 22:39 | 显示全部楼层
只能一部分一部分的调试了
xmshao 发表于 2016-6-22 16:00 | 显示全部楼层
不用外设关掉;
多余IO不用浮空,电平固定下来。
那个LSE的晶体及负载电容都有讲究,不用太随便。否则容易振不起来。
wangjakn 发表于 2016-6-22 16:52 | 显示全部楼层
stm32的RTC一直有bug楼主不知道?
 楼主| jacklow 发表于 2016-6-23 12:17 来自手机 | 显示全部楼层
把gpio设置正确后,功耗降到30uA,还是大了
 楼主| jacklow 发表于 2016-6-23 12:19 来自手机 | 显示全部楼层
stm32L的RTC也有bug?
JorryZhao 发表于 2016-7-15 16:43 | 显示全部楼层
楼主 遇到了同样的问题 换了三个照样出错 ,请问你32.768晶振旁路电容你用的多少,我分别用了6.8pf 10pf还是不行
lefeng 发表于 2016-7-15 19:11 | 显示全部楼层
多余IO不用浮空,会不会不稳定
Snow7 发表于 2016-7-15 20:29 | 显示全部楼层
LSE的晶体和负载电容要求比较高
