[经验分享] 可以用printf函数来打印串口调试信息
1729|9
 楼主| Edisons 发表于 2016-7-19 19:27 | 显示全部楼层 |阅读模式
下面这段代码是C8051F34x中串口调试的例程,可以用printf函数来打印串口调试信息。不明白是怎么实现的,貌似通常情况下,printf函数是需要改造一下才能用来打印信息的,请高手帮忙答疑,谢谢了.
#include <c8051f340.h>                 // SFR declarations
#include <stdio.h>
#define SYSCLK      12000000           // SYSCLK frequency in Hz
#define BAUDRATE        9600           // Baud rate of UART in bps
void SYSCLK_Init (void);
void UART0_Init (void);
void PORT_Init (void);
void Timer2_Init (int);
void main (void)
   unsigned char inputcharacter;       // Used to store character from UART
   PCA0MD &= ~0x40;                    // WDTE = 0 (clear watchdog timer
                                       // enable)
   PORT_Init();                        // Initialize Port I/O
   SYSCLK_Init ();                     // Initialize Oscillator
   UART0_Init();
   while (1)
      printf ("\nEnter character: ");
      inputcharacter = getchar ();
      printf ("\nCharacter entered : %c",inputcharacter);
      printf ("\n      Value in Hex: %bx",inputcharacter);
   P0MDOUT |= 0x10;                    // Enable UTX as push-pull output
   XBR0     = 0x01;                    // Enable UART on P0.4(TX) and P0.5(RX)
   XBR1     = 0x40;                    // Enable crossbar and weak pull-ups
   OSCICN |= 0x03;                     // Configure internal oscillator for
                                       // its maximum frequency
   RSTSRC  = 0x04;                     // Enable missing clock detector
   SCON0 = 0x10;                       // SCON0: 8-bit variable bit rate
                                       //        level of STOP bit is ignored
                                       //        RX enabled
                                       //        ninth bits are zeros
                                       //        clear RI0 and TI0 bits
   if (SYSCLK/BAUDRATE/2/256 < 1) {
      TH1 = -(SYSCLK/BAUDRATE/2);
      CKCON &= ~0x0B;                  // T1M = 1; SCA1:0 = xx
      CKCON |=  0x08;
   } else if (SYSCLK/BAUDRATE/2/256 < 4) {
      TH1 = -(SYSCLK/BAUDRATE/2/4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   } else if (SYSCLK/BAUDRATE/2/256 < 12) {
      TH1 = -(SYSCLK/BAUDRATE/2/12);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 00
   } else {
      TH1 = -(SYSCLK/BAUDRATE/2/48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   TL1 = TH1;                          // Init Timer1
   TMOD &= ~0xf0;                      // TMOD: timer 1 in 8-bit autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
   TI0 = 1;                            // Indicate TX0 ready
_gege 发表于 2016-7-19 19:30 | 显示全部楼层
在网上看到单片机程序中使用printf的例子,一般都是经过了改造的啊
Mozarts 发表于 2016-7-19 19:32 | 显示全部楼层
默认直接与串口打交道的吧!!!
Listate 发表于 2016-7-19 19:36 | 显示全部楼层
只要初始化串口,就能用Printf函数将相关内容送串口了,注意一定要在初始化完成后加上一句TI=1;
laozhongyi 发表于 2016-7-19 19:38 | 显示全部楼层
楼上是想让putchar能顺利将字符经由51单片机的串口发送出去?!
wanglaojii 发表于 2016-7-19 19:43 | 显示全部楼层
这个函数是类如下步骤完成的。
while(TI == 0);
SBUF=ucWriteData;
return;
zhouhuanの 发表于 2016-7-19 19:49 | 显示全部楼层
我很好奇  printf 这货是怎么找到串口并且发送数据的..
handleMessage 发表于 2016-7-19 19:51 | 显示全部楼层
pringtf相当于上层应用程序  串口配置相当于底层硬件驱动..
 楼主| Edisons 发表于 2016-7-19 20:00 | 显示全部楼层
受用了,以前用printf打印不成功,所以总是自己在程序中写个putchar 函数,可以打印字符和字符串,用printf调试时就方便多了。
bbapple 发表于 2016-7-19 20:03 | 显示全部楼层
假如说 我的单片机有两个串口   两个都初始化了  她会怎么去选择 最好能附有代码说明????
