出现好多问题,vmuser@Linux-host:~/L2.6.35_1.1.0_130130_source/source/ltib$ ./ltib
Don't have HTTP::Request::Common
Don't have LWP::UserAgent
Cannot test proxies, or remote file availability without both
HTTP::Request::Common and LWP::UserAgent
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path. Please
install/upgrade these packages on your host. If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package Minimum ver Installed info
zlib 0 not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
main:554
Started: Wed Aug 10 17:42:03 2016
Ended: Wed Aug 10 17:42:05 2016
Elapsed: 2 seconds
Build Failed
各位大侠看看,zlib http没有安装 不知道安装什么软件包
