[FPGA] H.264/AVC 和 H.265/HEVC decoder IP 核
2415|3
 楼主| 111_zh 发表于 2016-12-18 12:55 | 显示全部楼层 |阅读模式
WWAGO公司提供以下H.264/AVC ,H.265/HEVC的IP核,另外提供相应的platform solution。
(1) H.264/AVC HD decoder
(2) H.264/AVC 4K decoder
(3) H.265/HEVC HD decoder
(4) H.265/HEVC 4K decoder
给大家分享一下,有需要的可以联系:sales@wwago-inc.com
> H.264/AVC HD decoder : 支持下面的spec
- Standard: H.264/MPEG-4 Part 10 (ISO/IEC 14496-10 & ITU-T H.264)
- Profiles:  Constrained Baseline, Main & High proöles
- Video Resolutions: Up to 1920 x 1080
- Frame Rate:  Up to 60 fps
- Bit rate:  CABAC Bitrate: 40 Mbps. Scalable to 80 Mbps / CAVLC Bitrate: 80 Mbps. Scalable to 160 Mbps
- Chroma Format: Monochrome, 4:2:0 & 4:2:2
- Precision:   Bit depths from 8 to 10
- Input Format:  Elementary or Transport stream
- Output Format:  Decoded pictures in frame buffer. Optional serial output with embedded sync information
- Latency:   Ultra low latency of 10 ms
- Codec Flavors:   AVC – Ultra, H.264 4K, XAVC
> H.264/AVC 4k decoder : 支持下面的spec
- Video Resolutions: Up to 4096 x 2160
- Bit rate:   CABAC Bitrate: Up to 160 Mbps / CAVLC Bitrate: Up to 320 Mbps
- Precision: Bit depths from 8 to 10. Scalable to 12
- Codec Flavors: AVC – Ultra, XAVC 4K, XAVC 4K Intra
> H.265/HEVC HD decoder : 支持下面的spec
- Standard: HEVC/H.265 ( ISO/ IEC 23008-2 and ITU-T H.265 )
- Profiles:  Main, Main10, Main 12, Main 10 4:2:2 and Main 12 4:2:2
- Frame Rate:  60 fps
- Bit rate:  75 Mbps. Scalable to 150 Mbps
- Precision:  Bit depths from 8 to 12
- Latency:  As low as a few microseconds
> H.265/HEVC 4K decoder : 支持下面的spec
littler 发表于 2016-12-24 17:38 | 显示全部楼层
这是要卖吗?
