IMX6S,内核版本3.0.35
Pipeline is PREROLLING ...
Aiur: 3.0.7
Core: MPEG4PARSER_06.06.03 build on Jun 18 2013 14:52:11
mime: video/quicktime; audio/x-m4a; application/x-3gp
file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.1
Content Info:
URI:
file:///mnt/media/fileb.mp4
Idx File:
//.aiur/.mnt.media.fileb.mp4.aidx
Seekable : Yes
Size(byte): 52442358
Movie Info:
Seekable : Yes
Live : No
Duration : 0:04:03.500000000
ReadMode : Track
Track : 2
Track 00 [video_000000] Enabled
Duration: 0:04:03.500000000
Language: und
Mime:
video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)6
40, height=(in
t)360, framerate=(fraction)20/1, codec_data=(buffer)000001b0010000
01b58913000001
000000012000c48d8800a514042d1443
[INFO] Product Info: i.MX6Q/D/S
vpudec versions :)
plugin: 3.0.7
wrapper: 1.0.35(VPUWRAPPER_ARM_LINUX Build on Jan 22 2015 12:39:35)
vpulib: 5.4.16
firmware: 2.3.10.40778
aiurdemux0:sink: page allocation failure: order:11, mode:0xd1
[<8006fe34>] (unwind_backtrace+0x0/0xf8) from [<800e8b34>] (warn_alloc_failed+0x
c8/0x100)
[<800e8b34>] (warn_alloc_failed+0xc8/0x100) from [<800eb06c>] (__alloc_pages_nod
emask+0x4c8/0x6cc)
[<800eb06c>] (__alloc_pages_nodemask+0x4c8/0x6cc) from [<80072da0>] (__dma_alloc
+0xa4/0x300)
[<80072da0>] (__dma_alloc+0xa4/0x300) from [<800735d8>] (dma_alloc_coherent+0x54
/0x60)
[<800735d8>] (dma_alloc_coherent+0x54/0x60) from [<803d8d8c>] (vpu_alloc_dma_buf
fer+0x2c/0x54)
[<803d8d8c>] (vpu_alloc_dma_buffer+0x2c/0x54) from [<803d8f24>] (vpu_ioctl+0x170
/0x89c)
[<803d8f24>] (vpu_ioctl+0x170/0x89c) from [<801298c0>] (do_vfs_ioctl+0x80/0x54c)
[<801298c0>] (do_vfs_ioctl+0x80/0x54c) from [<80129dc4>] (sys_ioctl+0x38/0x5c)
[<80129dc4>] (sys_ioctl+0x38/0x5c) from [<80068fc0>] (ret_fast_syscall+0x0/0x30)
Mem-info:
DMA per-cpu:
CPU 0: hi: 90, btch: 15 usd: 77
Normal per-cpu:
CPU 0: hi: 18, btch: 3 usd: 5
active_anon:1544 inactive_anon:1754 isolated_anon:0
active_file:1933 inactive_file:15920 isolated_file:0
unevictable:0 dirty:4 writeback:0 unstable:0
free:33571 slab_reclaimable:396 slab_unreclaimable:1296
mapped:1299 shmem:1948 pagetables:123 bounce:0
DMA free:128684kB min:1468kB low:1832kB high:2200kB active_anon:2876kB inactive_
anon:20kB active_file:108kB inactive_file:26432kB unevictable:0kB isolated(anon)
:0kB isolated(file):0kB present:186944kB mlocked:0kB dirty:0kB writeback:0kB map
ped:0kB shmem:28kB slab_reclaimable:300kB slab_unreclaimable:824kB kernel_stack:
376kB pagetables:312kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:9
all_unreclaimable? no
lowmem_reserve[]: 0 69 69 69
Normal free:7232kB min:556kB low:692kB high:832kB active_anon:3348kB inactive_an
on:6996kB active_file:7624kB inactive_file:35488kB unevictable:0kB isolated(anon
):0kB isolated(file):0kB present:71104kB mlocked:0kB dirty:16kB writeback:0kB ma
pped:5324kB shmem:7764kB slab_reclaimable:1284kB slab_unreclaimable:4360kB kerne
l_stack:336kB pagetables:180kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_s
canned:8 all_unreclaimable? no
lowmem_reserve[]: 0 0 0 0
DMA: 262*4kB 220*8kB 163*16kB 135*32kB 124*64kB 98*128kB 70*256kB 39*512kB 24*10
24kB 11*2048kB 6*4096kB 0*8192kB 0*16384kB 0*32768kB = 139784kB
Normal: 654*4kB 579*8kB 308*16kB 221*32kB 93*64kB 37*128kB 12*256kB 3*512kB 0*10
24kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB 0*32768kB = 34544kB
9065 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
131072 pages of RAM
45432 free pages
69537 reserved pages
1445 slab pages
2935 pages shared
0 pages swap cached
Physical memory allocation error!
[ERR] mem allocation failed!
MPEG4_ASP_D_01.02.01 build on Dec 8 2011 18:23:35.
MFW_GST_MPEG4ASP_DECODER_PLUGIN 3.0.7 build on Jan 22 2015 12:41:23.
Track 01 [audio_000000] Enabled
Duration: 0:04:03.484448000
Language: und
Mime:
audio/mpeg, mpegversion=(Unhandled fault: external abort on non-li
nefetch (0x1018) at 0x2adff054
int)4, channels=(int)2, rate=(int)44100, bitrate=(int)1
20959, framed=(boolean)true, stream-format=(string)raw, codec_data
=(buffer)1210
Caught SIGSEGV accessing address 0x2a0f
