- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.0
- * $Revision: 4 $
- * $Date: 14/01/28 11:44a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] M051 Series ADC Interface Controller Driver Sample Code
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- #define PLL_CLOCK 50000000
- /* Define Function Prototypes */
- void SYS_Init(void);
- void UART0_Init(void);
- void AdcSingleModeTest(void);
- /* Define global variables and constants */
- volatile uint32_t g_u32AdcIntFlag;
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable ADC module clock */
- CLK_EnableModuleClock(ADC_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
- /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
- CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
- /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
- GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
- /* Configure the P1.0 - P1.3 ADC analog input pins */
- SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
- SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
- /* Init UART */
- void UART0_Init()
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Function: AdcSingleModeTest */
- /* Parameters: */
- /* None. */
- /* Returns: */
- /* None. */
- /* Description: */
- /* ADC single mode test. */
- void AdcSingleModeTest()
- uint8_t u8Option;
- int32_t i32ConversionData;
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| ADC single mode sample code |\n");
- while(1)
- printf("Select input mode:\n");
- printf(" [1] Single end input (channel 2 only)\n");
- printf(" [2] Differential input (channel pair 1 only)\n");
- printf(" Other keys: exit single mode test\n");
- u8Option = getchar();
- if(u8Option == '1')
- /* Set the ADC operation mode as single, input mode as single-end and enable the analog input channel 2 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
- /* Power on ADC module */
- ADC_POWER_ON(ADC);
- /* clear the A/D interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
- /* Enable the ADC interrupt */
- ADC_EnableInt(ADC, ADC_ADF_INT);
- NVIC_EnableIRQ(ADC_IRQn);
- /* Reset the ADC interrupt indicator and Start A/D conversion */
- g_u32AdcIntFlag = 0;
- ADC_START_CONV(ADC);
- /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function)*/
- while(g_u32AdcIntFlag == 0);
- /* Disable the ADC interrupt */
- ADC_DisableInt(ADC, ADC_ADF_INT);
- /* Get the conversion result of the ADC channel 2 */
- i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 2);
- printf("Conversion result of channel 2: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
- else if(u8Option == '2')
- /* Set the ADC operation mode as single, input mode as differential and
- enable analog input channel 2 for differential input channel pair 1*/
- ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
- /* Get the conversion result of the specified ADC channel */
- printf("Conversion result of channel pair 1: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
- else
- return ;
- /* ADC interrupt handler */
- void ADC_IRQHandler(void)
- g_u32AdcIntFlag = 1;
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* clear the A/D conversion flag */
- /* MAIN function */
- main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- /* Single Mode test */
- AdcSingleModeTest();
- /* Disable ADC module */
- ADC_Close(ADC);
- /* Disable ADC IP clock */
- CLK_DisableModuleClock(ADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC_IRQn);
- printf("\nExit ADC sample code\n");
- while(1);
